compression questions ???
1) What would the compression be with d15b2 & d16y8 head?
2) Also if I put SRP 10:5:1 pistons in the d15b2 with the y8 head what would the compression be?
3) Also what would be the hgihest compression I can use with pump gas?
sorry i can't help you with your compression question, but i have seen cars with 12.1 to 12.5 CR running 93 octane, these cars are also daily driven!
i'm running 11.2:1 right now with my mini-me, and have no problems at all with 94 octane. timing is set at stock. 12.5:1 is about the max with pump gas. you also must have it properly tuned to run that high. Wil from Exospeed runs his car with real high compression (i think its around 12.5:1) and its daily driven.
