B20 block and B16 head?
Old Mar 7, 2003 | 08:29 PM
JSPECHB's Avatar
Default B20 block and B16 head?
Alright heres the scoop. I got a 91 DX hatch. What needs to be done in order to drop in a B20 block and what mods have to be done to drop a B16A head on the B20 block. I heard this setup is badass. Will the B20 intake manifold..etc mount up to the B16A head? Fill me in with what you know...
Old Mar 7, 2003 | 08:35 PM
JalopySiR's Avatar
Default Re: B20 block and B16 head? (JSPECHB)
WOW, you need to do ALOT of homework. Welcome to H-T. No one is going to spoon feed you that much info. It's called the "search" button...
Old Mar 7, 2003 | 08:36 PM
EF_LSVtec's Avatar
i know a lot, but kinda redundant to retype and type and type and type and type and type and type and type and type...run a search, its called crvtec.
Old Mar 8, 2003 | 08:24 AM
smokey2.0's Avatar
Default Re: B20 block and B16 head? (EF_LSVtec)
yes sir, use the search button. but this can help! http://www.c-speedracing.com/howto/b20vtec/b20vtec.php
good luck!
Old Mar 8, 2003 | 08:59 AM
zCivic's Avatar
Well I'll offer help about the intake manifold, Just in case. You cann't use a B series non-vtec intake mani on a V-tec head bolt pattern is way off. Good Luck also gonna have to go DPFI to MPFI also tons of info available about that here there and everywhere. Best ECU would be a OBD0 PWO or PR3 you can go OBD1 using a rechiped P28 etc but will need a jumper to convert the plugs/wires from OBD0 to OBD1
[Modified by zCivic, 1:01 PM 3/8/2003]
EKdriverin703
11
Mar 10, 2011 01:21 PM
boostedefhatch
14
Mar 8, 2009 10:59 PM
urtz
Nov 11, 2006 11:48 AM
phillyd13
Oct 4, 2003 08:33 PM
