Cleaning Engine Bay
Old Mar 7, 2003 | 10:57 AM
CivicBoi's Avatar
Default Cleaning Engine Bay
I wanted to clean my engine bay, I didn't want to buy just any spray on product so if anyone can give me some tricks to cleaning the engine bay... Can I just use a high pressure water and do I have to cover any parts of the engine when doing this? ...need all the info I can get....thanks..
Old Mar 7, 2003 | 11:02 AM
altoid's Avatar
Default Re: Cleaning Engine Bay (crxboi)
steam high pressure steam easy and effective
Old Mar 7, 2003 | 11:04 AM
ScottEK's Avatar
I'm cleaning mine with a pressure washer tomorrow (if weather provides) but my engine is out. There was a thread about a week ago about whether or not to leave the engine running and the result of the debate was to have the engine off for obvious reasons with the air intake. Do you plan on just washing down the bay or the engine also?
Old Mar 7, 2003 | 11:05 AM
d357r0y's Avatar
cover the dizzy!!!
Old Mar 7, 2003 | 11:35 AM
KEVlN's Avatar
New User
Default Re: Cleaning Engine Bay (d357r0y)
1.high pressure spray your whole engine bay down once motor has cooled(stay away from distributor and cover intake with plastic bag-if you have an aftermarket intake.
2.spray the whole thing down with simple green and let sit for a few minutes
3.repeat step 1
4.repeat step 2
5.repeat step 1
6.spray down with armor all(everything) and let sit for a few minutes.
7.spray again with armor all and wipe it all off with a clean towel
8.you now have a bling bling engine bay.
*this is what I do everytime I clean my engine bay, and it comes out looking new everytime.
-kev
Old Mar 7, 2003 | 11:38 AM
Spaceballsthelunchbox's Avatar
No Big Whoop
I just bought a 1200 psi electrical pressure washer from Harbor freight.
I paid $60 plus $11 for a one year replacement warantee.
It's perfect for cleaning engines, not too powerful that might damage the electrical plugs, but powerful enough to remove oil and grime.
It left the tranny I cleaned looking practically new.
I didn't use any cleaner, just water.
something worth considering.
Old Mar 7, 2003 | 11:57 AM
CivicBoi's Avatar
Default Re: Cleaning Engine Bay (Spaceballs the lunch box)
Thanks.. for the inputs.. it really helps..
I just hope the wheather will co-operate tomorrow...
cheers..
Old Mar 7, 2003 | 12:21 PM
Doodoo's Avatar
Default Re: Cleaning Engine Bay (B8TeenRex)
3.repeat step 1
4.repeat step 2
5.repeat step 1
-kev
This works great. I did this except for the high pressure spraying. I just used the water hose. It turns out niiiiice. I use almost striaght Simple Green, very concentrated.
Just cover things that seem imporatant to you. I covered the filter, distributor and altenator and some electrical connections I didn't feel comfortable spraying with water.
Old Mar 7, 2003 | 06:54 PM
martini's Avatar
make SURE you use automotive simple green.
regular simple green is corrosive to aluminum...
Old Mar 7, 2003 | 06:57 PM
KEVlN's Avatar
New User
Default Re: Cleaning Engine Bay (martini)
Old Mar 7, 2003 | 08:21 PM
BIG RICH's Avatar
my engine bay sparkles. I suggest using steam if you can. I forgot to tighten my radiator cap(i know it was stupid) one time and I drove it around,and after a while steam was pouring out of my engine bay. Now I just spray it down with MEAN GREEN and it looks great.
Old Mar 13, 2003 | 01:35 PM
sixleggedbandit's Avatar
go with stream cleaning. less worries and just as effective
Old May 5, 2003 | 01:11 PM
OldSchoolHatch's Avatar
Default Re: Cleaning Engine Bay (sixleggedbandit)
How do you steam clean your engine bay?
Old May 5, 2003 | 01:34 PM
RCautoworks's Avatar
Default Re: Cleaning Engine Bay (OldSchoolHatch)
I asked this question a while ago https://honda-tech.com/zerothread?id=421124 , and the best advie I have heard is make sure your engine is cold when you start to clean it, and then as soon as your down cleaning it, start it up and let it run. This way the engine will get hot and dry the parts you can't get to.
von_clutch
Mar 16, 2011 06:40 PM
5G_Vtec
Apr 27, 2007 08:25 PM
realmc
Aug 9, 2005 09:20 PM
Spoonie Luv
May 2, 2003 03:26 PM
