Replacing catback with aftermarket...can I use jackstands?
Old Mar 7, 2003 | 10:40 AM
RacerBoy's Avatar
Default Replacing catback with aftermarket...can I use jackstands?
I want to put in my greddy catback myself, any chance I can use jackstands? What problems will I have removing and installing the new one?
Old Mar 7, 2003 | 10:46 AM
Creep's Avatar
Default Re: Replacing catback with aftermarket...can I use jackstands? (RacerBoy)
I would like to know too. I'm doing it on my teg soon.
I did a search an all I gathered was, soak all the bolts for
a long time, take the axleback section off first, then unbolt
at the cat (bolts sometimes frozen).
Old Mar 7, 2003 | 10:57 AM
Malgerus's Avatar
Default Re: Replacing catback with aftermarket...can I use jackstands? (Creep)
You can do it with jackstands. I just unbolted my cat, and it took a lot of penetrating oil, a big extension, and a lot of pushing. Can be done though. (hope you're not claustrophobic).
Old Mar 7, 2003 | 11:05 AM
ScottEK's Avatar
Default Re: Replacing catback with aftermarket...can I use jackstands? (Mr. S)
The cat bolts suck, I wasn't able to get them off with my four foot breaker bar because everything flexs with the hanging supports. If you have an air gun and a long extension you can hit all three bolts, including the top. The air gun took mine off instantly.
Old Mar 7, 2003 | 11:29 AM
DJ_SaNdOz's Avatar
Default Re: Replacing catback with aftermarket...can I use jackstands? (beta13)
get an impact if it's available, like stated previosuly-the cat bolts suck............
Old Mar 7, 2003 | 12:38 PM
REDBARON's Avatar
Default Re: Replacing catback with aftermarket...can I use jackstands? (dj_sandoz)
Yes, you can do it with Jackstands. It's very easy to do this. The only problem will be removing the nuts from the catalytic converter, but with some patience it comes out fine. I just used a simple ratchet with an extension and good old muscle.
...rohit
Feb 27, 2010 07:47 AM
Acidcrakker
Mar 3, 2008 08:46 PM
kornerk12
Nov 21, 2006 09:59 PM
94B18B1Teg
Mar 15, 2004 11:05 AM
f1uxx
Apr 23, 2003 12:40 PM
