All motor d series?
Old Mar 7, 2003 | 10:20 AM
crooked muffler's Avatar
Default All motor d series or turbo?
what should i do
take into consideration-
cost
power
reliability
[Modified by anti-ricecake, 2:33 PM 3/7/2003]
Old Mar 7, 2003 | 10:23 AM
altoid's Avatar
Default Re: All motor d series? (anti-ricecake)
hmm well turbo isn't all motor but thats the cheapest
Old Mar 7, 2003 | 10:47 AM
slowman's Avatar
I took way too long
Default Re: All motor d series? (altoid)
go with the turdbo
Old Mar 7, 2003 | 10:50 AM
Default Re: All motor d series? (slowmanEF)
is that exospeed **** really that fast?
i dont know turbo isnt going to be real reliable tho and id like to do it right so its going to cost alot all at once with all motor u do a lil at a time and turbos are mad confusing to me...
Old Mar 7, 2003 | 11:14 AM
ViperRedCRX's Avatar
turbo for sure
Old Mar 7, 2003 | 11:19 AM
ScottEK's Avatar
You might want a second opinion on this, turbos involve more tuning at one point but there are plenty of daily driving hybrid turbos.
Old Mar 7, 2003 | 11:28 AM
DJ_SaNdOz's Avatar
Default Re: All motor d series? (beta13)
there was a loooong post recently that exospeed was involved in, i kinda hijacked teh post from teh originator, anyways... from everything that was discussed & exospeeds site, their all motor d series packages look like they can contend, but it's all about what you want. if you are on a budget you may not want to do teh diy turbo b/c you will still need dyno time, and good tuning & that can potentially get expensive, if you want reliable exospeed's blocks/heads are rebuilt & cleaned & you can get stock or modded from them- that sounds much more reliable than a junkyard turbo, but yet again, it's all about preference.........either way good luck
Old Mar 10, 2003 | 09:59 AM
ExospeedAMcrx's Avatar
Default Re: All motor d series? (dj_sandoz)
well all I can say is if you do decide on a turbo setup. Do it right and get the proper parts, and dont half *** it. an sohc turbo setup is good even with a stock head. headwork on a turbo sohc, helps especially if you do decide to upgrade the valvetrain. which will let you take the rpms up higher. the best thing you can do to a boosted setup is the bottom end. the motor will hold better and boost more.
For all motor, you have to concentrate on the head and cam choice more than turbo setups. high compression bottom end with the appropriate cam can get you some nice HP numbers and great performanc if done right.
Wil
[Modified by exospeedAMcrx, 11:02 AM 3/10/2003]
Old Mar 10, 2003 | 11:28 AM
one slow d16's Avatar
Default Re: All motor d series? (exospeedAMcrx)
what would you recomend for an all motor sohc vtec? just getting ideas aswell
Old Mar 10, 2003 | 11:50 AM
Speed PHreak's Avatar
I'm gonna ***** this topic before I start a new one, since i'm thinking of doing the same thing. I'm going to rebuild the A6/Z6 mini-me in my 91Si. It's kinda my beater car, and it smokes a bit as it is. I'm looking too add some more pep to it. Something that'll pull till at most 8k. A bugeted build-up with mostly stock parts is my route. Here is my "**** list" of upgrades.
- A6 block -
ACL bearings
Rods - don't know A6 or ZC/A1 ?
Pistons - 88-89 Teg/ZC
-Z6 Head -
Mild Cam - recommendations?
Springs/reatainers
Port match
-other stuff-
Y8 intake mani
Chipped ECU with better fuel/timing maps
Other bolt-on crap.
This ought to be good for 12:1 compression and some decent HP figures. It should be *relatively* cheap since you can use mostly stock parts. I may skip the top-end build if it's gonna cost too much. I put the Z6 head on my A6 block and the VTEC didn't impress me too much. Then again I am running a RPM switch setup on an 88 teg ECU ...
[Modified by Speed PHreak, 3:59 PM 3/10/2003]
Old Mar 10, 2003 | 12:30 PM
4drEF's Avatar
Keyboard Humorist
Default Re: All motor d series or turbo? (anti-ricecake)
What is the car going to be used for? What kind of power are you looking to get?
Old Mar 10, 2003 | 12:33 PM
Default Re: All motor d series or turbo? (4drEF)
mainly street racing
im going to weight reduct the **** out of it
Urban Business
Guest
Posts: n/a
swap pistons and rods from the a6 block w/ something else. stock a6 compression blows.
jdmdc2_MA617
Dec 16, 2009 12:54 PM
Bignel00
May 14, 2008 10:17 AM
shibikku95
23
Jun 30, 2006 06:00 PM
allmotorek8
Jun 4, 2005 01:24 PM
DC2_Integra
Apr 2, 2003 04:48 PM
