I got a 87 Civic DX for free!!!!
Old Mar 7, 2003 | 08:59 AM
theclutchpoppa's Avatar
Default I got a 87 Civic DX for free!!!!
well my brother-in-law works at a Ford dealership and one of the lot boys had a 87 civic dx and the timing belt on it went...Well too make a long story short my bro talked him out of it for free and he gave it to me.So my question is since the timing belt went do you think it fucked something else up?he mentioned something about a valve being bent so i was wondering if i could use a 85 si head on it ?...the dx is carb and the si is fuel injected but my boy told me i could still use the head is this true?it didnt sound right to me.
Old Mar 7, 2003 | 11:25 AM
SpeedMonkeyRacing's Avatar
Default Re: I got a 87 Civic DX for free!!!! (theclutchpoppa)
just drop in 1.6 dohc motor from 88~89 integra. those motors are fairly cheap..in fact, i have one for sale for $350
Jeff-
Old Mar 7, 2003 | 02:06 PM
goforbroke's Avatar
MEAT PATTY
Default Re: I got a 87 Civic DX for free!!!! (Corporal-Jeff)
I'm in the same boat as you but I"m getting a 1984 civic automatic, blah. But I can't complain it free, but it needs a tranny. The head might be messed up, only way to find out is to put a timing belt on it and see what happens. I would rather put on a belt before ripping off the head. Not sure about the carburated head/fuel injected head. Only thing I know is that the si stock head has lower compression vs the dx head.
Old Mar 7, 2003 | 03:02 PM
Boman's Avatar
Jeff-
Actually your motor has different mounts since it's a 88-89.
The correct motor to swap would be from an 86-87.
[Modified by Boman, 4:02 PM 3/7/2003]
Old Mar 7, 2003 | 03:14 PM
juicedricer's Avatar
Default Re: I got a 87 Civic DX for free!!!! (Boman)
quit lyin u just tryin to play him u money grubbing ******
Old Mar 7, 2003 | 03:15 PM
yo that cat is lyin i did what u askin and everything werks fine and i woop everyones ***..
Old Mar 7, 2003 | 03:58 PM
Boman's Avatar
Default Re: I got a 87 Civic DX for free!!!! (juicedricer)
Not sure if the above two posts are directed at me. Regardless, in order to
swap in the D16A1 from an 1G Integra into a 3G Civic/1G CRX you need to get
it from a 86-87. This is because the later version motor 88-89 has a different
front mount.
Also, you have an 87 Civic Dx. This means it's carburated, which will require you
to swap to fuel injection. This is really labour intesive, but worth it in the end.
Your best bet is to find an Si parts car, since parts to do this could get pricey if
you're piecing everything together.
If you need any further help with options, etc. Check out www.redpepperracing.com/forms/
Hope this helps. Good luck.
Crx88dohc
Jun 9, 2008 03:25 AM
DOHClessEF-9
Jan 13, 2005 10:30 PM
Biglooney2
Mar 2, 2003 06:47 PM
civicracer1993
Jan 29, 2003 10:58 AM
J T*
Aug 6, 2002 07:33 PM
