help with a shimmy and clunk
Old Mar 7, 2003 | 07:07 AM
rage237's Avatar
Default help with a shimmy and clunk
Hello all, this post is for my brother, he has a 92 civic coupe DX, lowerd with nuespeed drop springs some form of a camber kit and a set of 16" rims, (sorry not sure on the specifics) well her is the prob, when he turns there is a slight thud/clunk, no its not the cv joint we already replaced both. he thinks it could be the bushings i have a bad suspision that it could be the diferential. any suggestions??
P.S. the sound is "comming" from the passenger side
Old Mar 7, 2003 | 07:14 AM
slomofo's Avatar
GDD Member
Default Re: help with a shimmy and clunk (rage237)
Are the springs properly aligned at the top of the strut? Are the struts bad? What size tire is he running (Width)?
Old Mar 7, 2003 | 07:16 AM
rage237's Avatar
Default Re: help with a shimmy and clunk (slomofo)
The springs naturaly align, the stuts could be bad but i dont think so, and he has 205 or 215's
Old Mar 7, 2003 | 07:19 AM
slomofo's Avatar
GDD Member
I have the green Neuspeed springs on my 92 civic and they don't align by themselves. I have to slowly lower the jack as I hold the spring in the right position so they seat properly.
If he has 215's, then the tires are rubbing when he turns.
Old Mar 7, 2003 | 07:23 AM
rage237's Avatar
they are not green i am not sure if they are neuspeed or not and its not the width or rubbing cause it just started but i belive the springs are lined up correctly
Old Mar 7, 2003 | 07:32 AM
slomofo's Avatar
GDD Member
Most the stuff I post just comes straight from my ***. I don't know what the problem could be.
Klimentiy
11
Dec 18, 2010 03:06 PM
V-techpwr
Honda Civic (2006 - 2015)
Jan 21, 2009 07:32 AM
608 Gangsta
15
Jan 17, 2008 12:04 PM
pdiggitydogg
49
May 15, 2004 06:15 PM
