FMU vac source can you have it off?
The retard who put my turbo kit on cut my stock fuel line to run the FMU, now 6months later I am fixing everything myself, with the help of hondatec38. We installed DSM injectors yesterday and got them running fine. Here is my question:
We didnt have enough fuel line to run the the FPR so we just took off the vac source of the FMU thinking it might just run inline if it didnt see any vacuum or Boost. Well when I boosted, My car started bucking. I think it is because of the FMU, so am I correct. When I take out the FMU should it work normally again?
Without the FMU hooked up to a vac source the car should run fine under vacuum. What are you using to control the injectors under boost?
hes using a vafc and chipped p28
anyway , BNate , just go get some vac line . or if you want ill bring some up tommorow i hve like 60 ft of 6mm line if you need some . i think by bypassing the fmu completely will correct it . but you still have some sort of vac cmoing off the fmu to what? that s might be the problem .
