reducing unsprung weight!!!! brake discs, etc
Old Mar 7, 2003 | 05:15 AM
austrian type-R's Avatar
Default reducing unsprung weight!!!! brake discs, etc
How to reduce unsprung weight?
- aluminium calipers
- aluminium suspension
- Ceramic brake discs (available for the ITR?)
- light weight rim
- light weight tire
- what else?
[Modified by austrian type-R, 9:02 PM 3/7/2003]
Old Mar 7, 2003 | 05:22 AM
jond's Avatar
Default Re: reducing unsprung weight!!!! brake discs, etc (austrian type-R)
I dont know if the first two would be considered unsprung weight or not.
Flywheel is a biggie...
Old Mar 7, 2003 | 05:25 AM
Default Re: reducing unsprung weight!!!! brake discs, etc (jond)
why a flywheel? Unsprung weight is what the suspension is not dapening like the rims, etc.
Dr Pooface's Avatar
Anything not supported by the springs is unsprung. Flywheel is not unsprung weight.
Try-
Lightweight lugs (lol)
ATS CF rotors
Old Mar 7, 2003 | 05:35 AM
Default Re: reducing unsprung weight!!!! brake discs, etc (Dr Pooface)
CF rotors? Cool, how much, where to get, you have a link
Old Mar 7, 2003 | 07:31 AM
powerofdreams8's Avatar
i hope your made of money... heres the link http://www.a-t-s-usa.com/ats-product...n-brakes.shtml Their rotors only weigh 3.8lbs!
[Modified by powerofdreams8, 4:32 PM 3/7/2003]
Old Mar 7, 2003 | 07:36 AM
Buckshot's Avatar
Default Re: reducing unsprung weight!!!! brake discs, etc (powerofdreams8)
those are badass!
too bad they are totally impractical
Old Mar 7, 2003 | 07:42 AM
Default Re: reducing unsprung weight!!!! brake discs, etc (Buckshot)
holy chit! Thats some expenive stuff......I guess it is not safe on road driving.
Old Mar 7, 2003 | 07:55 AM
Flux's Avatar
holy crap. Can you imagine showing up for a local autox event with carbon brake discs...
Old Mar 7, 2003 | 08:00 AM
io_burn's Avatar
New User
Default Re: reducing unsprung weight!!!! brake discs, etc (Flux)
I already got a set, I keep them locked up in my solid gold house
Old Mar 7, 2003 | 08:15 AM
tnord's Avatar
Default Re: reducing unsprung weight!!!! brake discs, etc (io_burn)
in a much more practical sense........many aftermarket brake rotors have aluminum hats that will usually save a couple pounds per rotor. they are expensive as well, but nothing like cf rotors.
Old Mar 7, 2003 | 08:35 AM
owen_the_soyboy's Avatar
easiest way is to swap over a civic cx 4 lug knuckle with 9" rotors
I'll sell you mine REAL cheap
Dont forget the lightweight "swift" springs as well !
Old Mar 7, 2003 | 08:41 AM
BlueR's Avatar
Default Re: reducing unsprung weight!!!! brake discs, etc (owen_the_soyboy)
what about the spring itself???
is it considered sprung or unsprung weight?
Swift makes lightweight springs
Old Mar 7, 2003 | 09:27 AM
SlapSmak's Avatar
http://www.avko.org/Books/Mastering_I_before_E.htm
wtf is leight??
Old Mar 7, 2003 | 11:02 AM
Default Re: reducing unsprung weight!!!! brake discs, etc (SlapSmak)
haha, I just noticed it, damn, to much in the www all day long
Old Mar 7, 2003 | 11:10 AM
I agree that those ATS rotors are impractical, but think about how much some of you would be willing to pay for a wheel that weighed 10 lbs less than the ones you have now. Hopefully as the technology advances the prices will drop. It sure seems like a CF rotor would wear out fast...
Old Mar 7, 2003 | 11:14 AM
deepgreengsr's Avatar
Inverted Struts. Is the best way. look at Bilsteins(sp) for the porsches. They are upsidown. that moves the strut body (the heaviest part) to the car. And then the body is not part of the unsprung weight. That is the best way to do it imho. youre other suggestions were alright. If you can't afford them Aluminum struts are a also. But they are expensive as ****. But inverted struts are the way to go!.
Old Mar 7, 2003 | 11:18 AM
BlueR's Avatar
Default Re: reducing unsprung weight!!!! brake discs, etc (deepgreengsr)
the WRX STI-RA spec also runs inverted spring /shock combo
Old Mar 7, 2003 | 11:21 AM
SPiFF's Avatar
Yup. Used a lot on IT cars. OPM sells kits for Hondas.
Old Mar 7, 2003 | 11:56 AM
DutchITR1689's Avatar
Ehhhh, Lightweight hub?
Lightweight driveshaft + joint?
Lightweight wheelbearing?
lightweight fork for the shocks...
Old Mar 7, 2003 | 11:59 AM
BlueR's Avatar
Default Re: reducing unsprung weight!!!! brake discs, etc (DutchITR1689)
or spoons
Old Mar 7, 2003 | 12:06 PM
Default Re: reducing unsprung weight!!!! brake discs, etc (BlueR)
or spoons
There is no spoon...
Old Mar 7, 2003 | 04:10 PM
Old Mar 7, 2003 | 04:14 PM
Hybrid ctr's Avatar
how much unprung weight does inverted shocks reduce (approx.)???
Old Mar 7, 2003 | 04:35 PM
NunRacer's Avatar
Default Re: reducing unsprung weight!!!! brake discs, etc (Hybrid ctr)
Who sells lighter weight brake rotors? I know Mugen does but what about the spoon rotors are they lighter than the stock rotors by a significant margin? I would love to change to lighter rotors if I could keep stock wheels and calipers.
