d16a1 and b18a valve specs?
Old Mar 7, 2003 | 04:44 AM
keithv's Avatar
Default d16a1 and b18a valve specs?
well as a follow to this thread, i need to find the d16a1 valve specs as well as the b18a. basically i am trying to find out what USDM valves i can use in my DOHC ZC.
i found all of the info below from the online CRX manual. if someone has a d16a1 manual and the b18a manual, they most likely can get me this info.
here is the html version of the document i have put together so far:
http://breaka19.netfirms.com/zc/valve_specs.htm
and if you want to add info to the excel sheet, you can download it here (right click, save as):
http://breaka19.netfirms.com/zc/valve_specs.xls
thanks.
Old Mar 7, 2003 | 05:40 AM
DJ_SaNdOz's Avatar
Default Re: d16a1 and b18a valve specs? (breaka_1_9)
you've got a sweet thing going man; good luck!
Old Mar 7, 2003 | 09:35 AM
altoid's Avatar
Default Re: d16a1 and b18a valve specs? (dj_sandoz)
http://hybrid2.honda-perf.org/tech/zcinfo.html
there is some info that that page, didn't quite go through it all though.
Old Mar 7, 2003 | 09:40 AM
keithv's Avatar
Default Re: d16a1 and b18a valve specs? (altoid)
if you click this link...
you will see that i have the ZC specs. i need to find the d16a1 specs and the b18a specs.
Old Mar 7, 2003 | 09:49 AM
Superhatch's Avatar
I have the d series somewhere...let me find it.
-Jake
Old Mar 11, 2003 | 03:55 AM
keithv's Avatar
Default Re: d16a1 and b18a valve specs? (Superhatch)
bump...someone must have an 86-89 teg manual and the 90-93 teg manual...
Old Mar 11, 2003 | 08:38 AM
wronghand's Avatar
Hey man I have been looking for this info since you posted friday. I hope this helps.
http://pub143.ezboard.com/fhondadser....topic&index=2
I now realize that the links no longer work. That being said you may want to check with mista to get the charts.
[Modified by wronghand, 12:45 PM 3/11/2003]
Old Mar 11, 2003 | 08:48 AM
keithv's Avatar
Default Re: d16a1 and b18a valve specs? (wronghand)
with a little detective work, i found this....
http://www.codyscafe.com/~mrbone/pics/Misc/specs2.jpg
thanks wronghand!!!
i have now updated the doc, but i still need more info!!!
B and B
Jun 29, 2009 11:36 PM
infamouskillas
Jul 8, 2008 08:07 PM
Wicked_CRX
Jul 16, 2003 04:38 PM
jdmcrx2134
May 13, 2003 01:17 PM
