effective final drive equation when changing tire sizes?
Old Mar 6, 2003 | 10:43 PM
Black R's Avatar
25 Year Member
Default effective final drive equation when changing tire sizes?
Anybody know the formula?
Old Mar 7, 2003 | 02:42 PM
Black R's Avatar
25 Year Member
Default Re: effective final drive equation when changing tire sizes? (py1091)
Ok, so for the following:
195-60-14
1. Sidewall height (in mm) = 195 * .60 = 117 mm
2. Sidewall height (in inches) = 117 mm / 25.4 = 4.606 inches
3. Outer diameter (in inches) = 14 + (2 * 2.971) = 23.21 inches
Did I do the calculations correctly?
This is a 14" azenis on stock hx rim... I wanna see how the acceleration is affected compared to stock rims and tires... with the same engine and tranny combo...
[edit] fixed calculations..... [/edit]
[Modified by Black R, 7:16 PM 3/7/2003]
Old Mar 7, 2003 | 03:23 PM
Black R's Avatar
25 Year Member
.....ok, I see what you did.
I've had this formula for a long time (how to calculate the total height of a tire):
{[(tire width) * .(tire aspect ratio) * 2] / 25.4} + (rim diameter) = total tire height
So, 215/45/16 would look like this:
{[(215) * .(45) *2] / 25.4 } + (16) = 23.6
But how does this affect the acceleration? I mean, how does it make the 4.4 final gear feel now? (compared to stock tires at 23.44 height?)
Old Mar 7, 2003 | 03:55 PM
96dc2's Avatar
Default Re: effective final drive equation when changing tire sizes? (Black R)
smaller diameter (compared to stock) = shorter (numerically higher) final drive
larger diameter = longer (numerically smaller) final drive
23.6>23.44 therefore you would have a longer final drive. but the difference there does not seem significant to affect acceleration much.
Old Mar 8, 2003 | 07:06 PM
vtec.dc2's Avatar
don't have the equation.. but you can get some idea of how things will be when you change tire diameter - i placed different tire sizes with 4.4 final drive - but you can change it around..
http://bob123e.tripod.com/askbob/Gea...Calculator.htm
HamiltonRex
Dec 30, 2004 05:08 PM
jond
Mar 3, 2002 06:30 PM
JohnnyBoy
Jan 19, 2002 09:45 AM
Jordan_4WS
Oct 18, 2001 12:09 PM
