Need cam advice. (I got a PnP head, but what cams?)
Okay. Here's what I got:
I have a port and polish head (B16A2 pr3-2)
Ferrera valves. New guides.
FULL crower valve tain (68185 springs, 87093 retainers)
I'm thinking
Toda Spec B or Cs
Jun Type 2 or 3
Skunk2 Stage 2
Crower cams 63412 or 63413 (or the 63403 older ver)
I'm a noob calculating the lift and coil bind so please help me decide.
My pistons CR is 11.5:1 and my CR is 12:1 (due to thin headgasket and mill
head) so I have the compression to
run big cams, yea?
Please don't tell me to go w/ Crower just because all the parts have to be
the same brand.
Thank you a lot.
[Modified by s2geezy, 7:15 AM 3/7/2003]
I'm thinking
Toda Spec B or Cs
Jun Type 2 or 3
Skunk2 Stage 2
run big cams, yea?
the same brand.
Thank you a lot.
y not try crane stage 3.
they are similar to jun3 and way cheaper.
also, that is good compression already.
itr/ctr cams will give you the best hsrpwr for the street if your not reving past 8 or 9.
if u are reving hig. jun3, toda, skunk2 stage, crane stage3 any of thoes will work.
i have a similar set up, my cr is 11.8 i put crane stage 2.
my base dyno was 160 hp and 118 tq.
after the cams, 175 hp and 123 tq. and that is reving to 8k. the graph clearly shows that the horsepwer was still going upwards at 8k. therefore if i were to rev higher i could easily reach 185 hp.
the crane 2 doesnt require cam gears, all i did was merely put them in, and retarded the dist timing alittle. vtec is set at 6k.
I've been on the Crower 63403s for almost 2 years and couldn't be happier. They now recommend the 68188 spring for these cams, which I find somewhat disturbing, but oh well. The new springs are far stiffer.
for the money, the skunk stage 2s are freaking great cams. from what I have seen, they are very comparable to jun 3s in power production and run about $750 for the set. As far as valvesprings I am considering these cams and I am tossed up between toda and stock springs with portflow inners.
can i use mt 68185 springs w/ 63403 or 63402 cams?
thanks.
I did make 198whp w/ 11.36:1 compression stock bore. I've since had the block sleeved and installed JE 12.5:1 85mm pistons. I'm working on installing an ITR LSD and 39# injectors at present. I won't know how much power I can squeeze out of this setup for a few more weeks at this rate, but I'll be hoping for somewhere near 230.
I called Crower about the rather large jump in recommended spring pressure on those cams and was told it was so they could be run past 10k rpm and that I won't have any trouble w/ the 68185 springs I've been using. Given that my redline is 9300 and I stopped making power at 8800ish last time I dyno'd I don't think stiffer springs would be productive and would actually cost power.
as long as I dont rev pass 9k? Yea, I was told my springs are good till 10k.
I just hope that they dont bind and break my cams like other people have experienced.
So, I should be fine running any Crower cams (since I got full crower valve train)as long as I dont rev pass 9k? Yea, I was told my springs are good till 10k. I just hope that they dont bind and break my cams like other people have experienced.
compared to Crower? I mean, $750 sounds good but JUN 3 are only $880
shipped. As for Crower, you can get them for $570 shipped and its
the Stage 3 all-motor profile (63403)
Yeah 10k is what I was told by the man himself Brian Crower for the 68185 springs. I put my Crower schtuff in 2 years ago this month and my cams look like they did the day I got them.
Is there any specific reasons why you think Skunk2 is good? How are they
I just installed skunk 2 stage 2 so far i like them alot but i still got alot of tunning with them ill find out how good they are when my computer gets in
Try Ef-1.com cams go with the JUN Killer
nice cams i'm order my cams springs and retainers right now
EDIT: produces +5 HP and +5 torque on their untuned cams versus tuned Jun 3 cams
very good IMO
[Modified by KoRE, 7:26 PM 3/9/2003]
very good IMO
b16powwer
Oct 7, 2002 07:35 AM
