Valvespring Compressor that Works on D Series Retainers?
Old Mar 6, 2003 | 09:23 PM
inspyral's Avatar
Default Valvespring Compressor that Works on D Series Retainers?
I'm looking for a valvespring compressor(c-clamp type) that will work on my D16Y8 retainers. I picked one up at Pep Boys, but I was reading the package, and it says the smallest retainers it will work with are 7/8" retainers. I pulled my valvecover and measured my retainers, and they're about 13/16", a bit smaller than 7/8". Does anyone know where I can get a valvespring compressor that will work with 13/16" retainers? Should I just try bending the prongs on the one I have? I don't have an air compressor, so all those "on-the-car" type valvesrping compressors aren't really an option. I need the C-clamp style to hold the valve shut while I compress the springs and remove the keepers and retainers.
Old Mar 7, 2003 | 08:13 AM
inspyral's Avatar
Default Re: Valvespring Compressor that Works on D Series Retainers? (inspyral)
Old Mar 7, 2003 | 07:37 PM
HEAD's Avatar
snap-on makes one it's 175.00 works really well
Old Mar 7, 2003 | 09:20 PM
TimoneX's Avatar
New User
Default Re: Valvespring Compressor that Works on D Series Retainers? (HEAD)
I use this $50 knock-off of the snap-on tool. Works perfectly.
http://www.northerntool.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=6970&langId=-1&catalogId=4006970&PHOTOSn&TEST=Y&productId=297037&categoryId=0
Anyway. It's at northerntools.com just do a search for "valve spring".
[Modified by TimoneX, 10:24 PM 3/7/2003]
Old Mar 7, 2003 | 09:23 PM
HEAD's Avatar
Default Re: Valvespring Compressor that Works on D Series Retainers? (TimoneX)
who makes it?
Old Mar 7, 2003 | 09:24 PM
inspyral's Avatar
You need an air compressor to hold the valves closed with those two, right? Or can they be used without a compressor?
Old Mar 7, 2003 | 09:27 PM
TimoneX's Avatar
New User
Couldn't tell ya. It comes in a generic green & white box and has a generic molded plastic case. I've used it 3x since I picked it up and it works perfectly.
Old Mar 7, 2003 | 09:29 PM
TimoneX's Avatar
New User
You need the air compresser to keep the valves from falling when you remove the keepers w/ the head still on the car. I always remove the head to do valve train work though, leaning over a car that long gives me a backache.
Old Mar 7, 2003 | 09:31 PM
inspyral's Avatar
So you can use it without an air compressor if you pull the head? Do you just lay the head on some folded up towels or on a workbench or something? I'm going to be changing my valve stem seals for the first time.
Old Mar 7, 2003 | 10:09 PM
TimoneX's Avatar
New User
Yeah. You don't need air if you have the head off. Sure it's your valve seals that are leaking? A good rule of thumb is if it smokes when you're accelerating it's the rings, if it smokes when you're decelerating it's the valves seals. Good luck.
Old Mar 7, 2003 | 10:15 PM
inspyral's Avatar
It actually doesn't smoke at all out of the tailpipe, but if I open the oil filler cap, it smokes a bit out there, and my compression on #3 is 90psi and it goes up when I put oil in there and retest. My dipstick also popped out under boost when this started, spraying oil all over the underside of my hood. I'm assuming it's my #3 rings, but I'm just going ot change the seals anyway because they're like $0.70-0.80 a piece. Thanks for all the help.
Old Mar 7, 2003 | 10:24 PM
TimoneX's Avatar
New User
NP good luck bro.
95_Civic_4dr
Sep 30, 2010 07:34 AM
prolifikproficy
Jun 16, 2008 09:04 AM
dustin_crxsi
Jan 29, 2007 11:04 AM
inspyral
Mar 7, 2003 08:13 AM
