cruise control not working
Old Mar 6, 2003 | 06:13 PM
munscher's Avatar
Default cruise control not working
So i removed the cruise, sunroof, and dimmer switches to put in the LEDs i've got... the sunroof and dimmer work fine.... the cruise control light will not come on when the button is depressed (with all stock bulbs in there, haven't touched it yet) my car will not set either, so its not just the light being out (which i tried several good bulbs too)... anyone have any ideas????
I checked the fuse, its good
Old Mar 6, 2003 | 06:46 PM
nikolai.'s Avatar
Default Re: cruise control not working (munscher)
make sure everything is plugged in...EVERYTHING.
find the cruise box under the dash and follow every lead and make sure they are connected.
if that doesnt work, get a helms and a DMM and have fun...
i had the same problem. didnt get it fixed until i got my helms in and could test all the leads. burnt clutch switch....$30
Old Mar 6, 2003 | 07:13 PM
Quiklude's Avatar
Default Re: cruise control not working (NB)
fuse #14 7.5A under dash fuse box (Cruise control fuse), By the look of the diagram , you have the switch on the power side of the circuit, and the light and the actuator run parallel off of the switch, so if both dont work sounds like you are getting now power to it, check the fuse first, and if not that make sure you are getting power to the switch
[Modified by Quiklude, 4:20 AM 3/7/2003]
Old Mar 6, 2003 | 07:25 PM
munscher's Avatar
well......... it looks as though the positive lead is shorted somewhere.... so i need to test everywhere down the line until i find it.... i'm guessing the wires are all wrapped and bundled together and i'll have to rip 'em all apart? how expensive is a new harness?
Old Mar 6, 2003 | 09:19 PM
Quiklude's Avatar
alot more than you want to pay, usually shorts will happen at connections, (might be a short or just an open), check all your connetors in that circuit, make sure the pins are making contact in the connector
Old Mar 7, 2003 | 02:17 AM
EH2DX's Avatar
hey, if i don't sell my car, i'll sell you my complete cruise control if you like... or just the harness... hit me up later if you still need it (if you don't fix it that is)
good luck
Old Mar 7, 2003 | 11:34 AM
MugenPoweredLude's Avatar
Default Re: cruise control not working (BB1)
well a cheap alternative if you have a 5spd is to yank the cruise control all together..my .02 cents
ej#1
Mar 17, 2008 03:54 PM
nwn4772
Apr 19, 2007 03:21 PM
tgreene2098
Mar 15, 2007 11:16 AM
da_33
Jun 12, 2006 11:26 AM
NeoGSR
Nov 1, 2002 10:24 AM
