VTEC disengagement when taking hard turn?
If turning very hard would VTEC disengage because of the shift in oil? Just a thought because my friend took a hard corner in his DOHC VTEC civic today and he said that the car hesitated while already in VTEC a little bit.
Tried to search, but I'm dumb.
This prompts many of us to run w/Mugen or Spoon baffled oil pans, as I do.
I used to take some pretty crazy turns going pretty crazy speeds and never had this problem.
This is the only place it happens to me, but I can reproduce it at anytime. While doing the sweeping left in 3rd at 6.5-7k rpms, the cars stutters. Feels like hitting the rev limiter, but it is just vtec disengaging. Then I get a check engine light. Both times the code was vtec failure. I figured it was oil starvation. I avoid that now.
Low oil. Could also be low gas. I find it hard to believe you can oil starve a B18 full oil on the street with street tires. I have been racing my GSR for 3 years with the stock pan and have YET TO DROP OFF THE CAM AT ANY TRACK. This is with R tyres, good suspension, etc. I also keep the oil at 1/2 qt over or full at least.
Moral of the story, check yout oil and keep it filled.
Since it sounds like its a hybrid, how bout a loose wire?
as I was thinking...Cause ya know these Hybrids can be a pia
[Modified by Bbasso, 5:23 AM 3/7/2003]
Yes, it is possible for momentary oil starvation to cause the car to fall off the cam to protect the motor.
This is usually due to a low oil level, but it's possible in extremely high-G manoeuvres for the phenomenon to occur despite a normal oil level.
I had this problem before also, my car was not low in oil. What had happen is the seal on the oil pick up was not perfect.
Has the bottom end been cracked open.
Also does your oil light come on when making the turn.
I would check with an oil gauge first, if it reads low I would investigate.
I ended up spinning a bearing because of this.
[Modified by MARC P, 8:00 AM 3/7/2003]
vtec is harder to hear in gsr (asumeing stock cams). maybe you are falling out and just not hearing it.
Either way, there are more Honda racers running stock pans then not. Oil starvation in turns is just not a problem on Hondas.
Good one! You can hear it just fine with an AEM and open exhaust. Even so, I think the mad loss of power and the CEL would clue me in.
CEL light would not come on falling out of vtec.
On a GS-R with stock exhaust, header, etc this is true. On a race car, this is far from true.
it would if the ECU recorded a VTEC Pressure failure. Granted, that wont generally happen in this case...
I think the worst just happened. Heard from a friend that his motor is gone.
I'll talk to him today to see what's up...
At high rpms you WILL hear and feel it when you fall out of vtec in a gsr. My exhaust, headers and intake attribute to this also probably.
My motor has never been opened.
