For anyone that wants to know
Old Mar 6, 2003 | 04:45 PM
fsarfino's Avatar
Default For anyone that wants to know
Just figured I would post something I just found out for anyone that cares.
a OBD 0 B16A distubutor will work on a B18A (90-91 teg) however only the top leg of the distubutor will bolt up, also the Ignition timing will not be correct due to not being able to advance the distubutor enough. So this will work if you are in a bind.
Just figured I'd share the info since my B18A distubutor died due to a bad bearing and I tried this since I had a B16A distubutor laying around.
Old Mar 6, 2003 | 05:10 PM
dfoxengr's Avatar
Default Re: For anyone that wants to know (fsarfino)
you can use all bseries dists intercgangeably assuming they are the right OBD and you dont mind having only 1 leg on there...
Old Mar 7, 2003 | 03:59 PM
fsarfino's Avatar
Default Re: For anyone that wants to know (hybridvteceg)
I dont think that I would trust 1 bolt holding it on.
Old Mar 7, 2003 | 04:07 PM
dfoxengr's Avatar
u sed it for awhile like that and its ok...i thought u said thats what u did, since only 1 leg bolts up thats only 1 bolt..lol
Old Mar 8, 2003 | 09:37 AM
fsarfino's Avatar
well I used it for about 2 blocks to see how it would run. But then I decided to not be a cheap bastard and bought a used distrubutor. (the reason I even tried this was my original distrubutor had a seized bearing)
BoosteDa7
Oct 3, 2006 08:29 PM
blockhondab18c5
30
Oct 17, 2005 11:40 AM
4inspeed
Jun 3, 2003 03:24 PM
