Timing Belt Cover
Old Mar 6, 2003 | 02:34 PM
MidoriEK4's Avatar
Default Timing Belt Cover
should i install the middle timing belt cover? also is this ok for daily driving, just having the lower cover?
Old Mar 6, 2003 | 02:48 PM
integra6650's Avatar
Default Re: Timing Belt Cover (NA CRX Si)
middle as in between the cams gears and the head otherwise im confused i only know of 2 pieces upper and lower and i would highly recomend using it
Old Mar 6, 2003 | 03:10 PM
MidoriEK4's Avatar
Default Re: Timing Belt Cover (integra6650)
yeah upper is the middle. i assume. cause there is the valve cover then the middle piece and then the lower one. y not have the middle one. right now i run without the top piece on my SOHC
Old Mar 6, 2003 | 03:57 PM
keeps debris further from your crank/timing belt
732xghost
Sep 9, 2007 10:02 AM
trecool44
Feb 3, 2006 05:47 AM
BlueShadow
Jan 12, 2005 08:38 PM
216.226.142.95:27016
Oct 8, 2003 10:01 AM
