Need help removing the breather chamber off a b16a2...
Old Mar 6, 2003 | 02:30 PM
MeanGreenEG9's Avatar
Default Need help removing the breather chamber off a b16a2...
Sup fellow HT peeps. I need your help yet again. I believe oil is leaking out of my breather chamber that is located right next to the oil filter behind the block. I see only one bolt on the bottom so I'm not too sure what is holding it up from the top... has anyone ever had an oil leak from here? when you removed the breather chamber did you have to disconnect all the hoses to get it off or is there a bolt up thop that is missing? TIA.
Old Mar 6, 2003 | 06:10 PM
TREVER's Avatar
Default Re: Need help removing the breather chamber off a b16a2... (B16aEJ)
Theres one bolt and two hoses. One hose goes to the pcv valve the other goes to the crankcase. The hoses seal with grommets either could be leaking. There is also a o ring that seals the drain back to the block it could also be leaking.
Old Mar 7, 2003 | 11:20 AM
Default Re: Need help removing the breather chamber off a b16a2... (TREVER)
So the hose is the only thing that is holding up the breather chamber box other than the one bolt on the bottom?
Old Mar 7, 2003 | 11:46 AM
skunked's Avatar
Yep
Backmarker
Aug 18, 2016 07:18 PM
mr.mengo
Mar 1, 2013 04:05 PM
missionaryrider
Jan 15, 2010 08:23 AM
SdGSR01
Apr 2, 2005 01:50 PM
