ECU throwing codes (help)
Old Mar 6, 2003 | 12:31 PM
IamVtec's Avatar
Default ECU throwing codes (help)
My ecu is throwing the codes 6-coolant temperature,10- Intake air temp,13-Atmosphric pressure, and 20-Electric load.
I was running a PG7 on a d16a6 with HF intake manifold. Is that why its throwing this code? and if i replace the Intake manifold with the d16a6 one will it solve this problem? Thanks
Old Mar 6, 2003 | 03:20 PM
bryant's Avatar
Default Re: ECU throwing codes (Full Throttle EF)
Sound like your IM is the problem. Did you make sure to replace all gaskets when you put the new one on?
Old Mar 6, 2003 | 03:53 PM
IamVtec's Avatar
Default Re: ECU throwing codes (Bryant)
well i havent replace the HF IM with the Si one yet, and i will replace the gasket on it. But at the moment Im still using the HF IM and i used the pg7 ecu on it, and thats why im guessing the HF IM cant handle/take the PG7 ecu. since the HF IM is a pos. I put the HF ecu back on but its still throwing the codes. But i guess i will have to reset the ECU.
Old Mar 6, 2003 | 03:55 PM
bryant's Avatar
So your converting the car to and Si IM and you just havent got the HF one off yet?
Old Mar 7, 2003 | 02:21 PM
IamVtec's Avatar
yes.
I have a d16a6 with the HF IM on it. But will be changing it shortly.
Old Mar 7, 2003 | 02:48 PM
bryant's Avatar
Okay, do that first. Then see if you have anymore problem.
CRX MASE
May 19, 2008 03:27 PM
1990-hf
15
Feb 19, 2005 08:38 PM
Tyson
Aug 10, 2004 12:50 PM
1fst4
12
Jun 23, 2004 01:48 PM
IamVtec
Aug 29, 2002 09:58 PM
