popping noise?
Old Mar 6, 2003 | 10:15 AM
rustycivic's Avatar
Default popping noise?
I keep hearing a slight popping noise coming from the front my drivers side. It sounds like it is coming from somewhere around the wheel area? This only happens when I hit the brakes! Could it be my upper ball joint? maybe my axle? I checked the suspension and everything seems tight. Any ideas on what it could be?
Old Mar 6, 2003 | 12:34 PM
altoid's Avatar
Default Re: popping noise? (rustycivic)
usually the cv joint
Old Mar 7, 2003 | 09:55 AM
tpr's Avatar
tpr
The CV joints usually pop only when turning, unless the axle is "very" worn. Typically the driverside axle will pop when turning left. Recheck the suspension components. Upper/lower ball joint and tie rod end. use a pry bar to see there is relative motion between the components.
acmoc
Nov 28, 2012 10:20 AM
toukao35
Oct 6, 2011 07:20 AM
TomFin
Suspension & Brakes
Mar 6, 2006 11:20 AM
2nd_Gen
Aug 23, 2005 01:08 AM
GReddy SI
12
Jul 17, 2003 04:07 AM
