Door Light, Cabin Light, and Light NOtifier don't work
Old Mar 6, 2003 | 03:10 AM
BlackB18CTeg's Avatar
Default Door Light, Cabin Light, and Light NOtifier don't work
The Door light on the gauges in the front is lit even though no door is open, the cabin lights dont come on, and the sound that tells you your light are on doesnt work. I think it has to do with the fuse, since I was messing around with them yesterday. ANy help would be appreciated.
Old Mar 6, 2003 | 09:36 AM
akhom2's Avatar
Default Re: Door Light, Cabin Light, and Light NOtifier don't work (BlackB18CTeg)
Well check them fuses. Check the door pins if you messed with that. Check the dome light to make sure it is switch on and bulb is not burned out.
Old Mar 6, 2003 | 10:45 AM
GSRpower's Avatar
Default Re: Door Light, Cabin Light, and Light NOtifier don't work (akhom2)
Check the ground wire too. Once the lights and door chime didn't work for me and the ground wasnt secured anywhere.
[Modified by GSRpower, 1:45 PM 3/6/2003]
[Modified by GSRpower, 1:46 PM 3/6/2003]
Old Mar 6, 2003 | 04:23 PM
Default Re: Door Light, Cabin Light, and Light NOtifier don't work (GSRpower)
where is hte ground wire?
also, the intermitent wipers dont work or rear defogger. I don't think it an individual problem.
checked fuse 10A, and replaced, nothing happened. What fuse would it be.
[Modified by BlackB18CTeg, 1:26 AM 3/7/2003]
Slade.
May 23, 2015 01:12 PM
Aftermath_Hatch
Dec 2, 2009 01:59 PM
streetuner
Jun 26, 2006 06:48 PM
ringerracer
21
Nov 3, 2004 07:40 AM
rice4life
Jun 14, 2002 07:34 AM
