Rod Bearing?? can I use a different size?
I need to replace my rod bearings. I was wondering if I can get a different one from what I had. I have blacks and brown is the closes to it. Would it be alright for me to use a different size rod bearings (all 8 of them). Would there be any advantages or disadvantages?
thanks for reading this
Get the correct bearing then plastigauge all your journals... If everything comes up within spec then you're set, if not then replace with the appropriate bearing... Good Luck
