People with D16y8 intake mani swap.
I just finished installing my Y8 mani to the A6 engine, and i'm running B&M adj FPR. I would like to know what is the best psi setting for this swap? BTW, i'm running a y8 rails and y8 FPR. I will some pics of the swap tomorrow.
I run 40PSI but thats only because I have a Walbro 255 LPH/HP fuel pump and thats as low as I can get it. I would suggest about 36-38 usually
From: the asshole of america..., upstate new york, USA
One plugs in the back, one on the front for the FPR and your car should only have 1 hose left which is the map sensor which if your using the Z6/Y8 T/B its on top extend the harness.....
yeah id put it to stock...which i think mine is like 34-36psi. whatever lets it idle good. how didi you run all of the vaccum lines? i was mapping mine out and i think there needs to be one more line in the manifold for everything. but i just looked real quick so ill have to check again.
P.S. I'm running a stage 1 crane cam so it will varies the out put from diff cars.
About the throttle backet, Use the old Y8 one and flip it over. Works like a charm
[Modified by 4thGSi, 11:13 AM 3/6/2003]
kkim
12
Jul 5, 2005 05:41 PM
mengy007
Sep 19, 2004 01:37 PM
1.8Tities
17
Mar 11, 2003 09:38 PM
