Balancer shafts.?
Old Mar 5, 2003 | 07:41 PM
noslude93's Avatar
Default Balancer shafts.?
I searched for this but could not find any thing.
I would like to know If I can Just NOT put on the belt and run it that way with out it not hurting any thing?
The motor is fully balanced so I am not worried about it vibrating or any thing. Can any one help me here?
Old Mar 5, 2003 | 07:42 PM
noslude93's Avatar
Default Re: Balancer shafts.? (noslude93)
Sorry I am running a H23 .. any one
Old Mar 5, 2003 | 08:01 PM
user 9782082308's Avatar
I asked this a few days ago. You "should" be fine if your engines balanced. And, yes, just keep the belt off.
Old Mar 5, 2003 | 08:05 PM
noslude93's Avatar
Default Re: Balancer shafts.? (racerx)
So just put it together as normal just leave the belt off and I will be fine.
Old Mar 5, 2003 | 08:07 PM
PUREVIL's Avatar
damnit the same **** happend to me in the Accord Fourm.. about me throwing a code 7! it was really slow responce.. sorry i cant help you out bro..
i thought more peeps would know whats up on this..
humm whatever i guess..
not many built h22 or h23s on the page i guess, or atleast peeps who know what they are talking bout.. J/P..
later.
Old Mar 6, 2003 | 06:00 AM
noslude93's Avatar
Default Re: Balancer shafts.? (BottleFedBigBodyLX)
I would like to get more then one person to tell me that it is ok to do this.
Old Mar 6, 2003 | 06:03 AM
Robb's Avatar
Yes, you can just leave the belt off, It will not cause any problems. I you want to pull the shafts out, you will have to plug up the oil holes that oil the balance shafts.
Old Mar 6, 2003 | 08:26 AM
noslude93's Avatar
Default Re: Balancer shafts.? (Robb)
What would happen if you didnt , you would lose oil psi?
Great I think I am just going to not put the belt back on .
That should be good for a little faster reving right?
Old Mar 6, 2003 | 08:34 AM
satan_srv's Avatar
pretty much you should be fine. But I'm not going to tell you it's okay. I mean it does increase vibration, no direct causes of engine failure though, it's your risk to take.
Robb's Avatar
Yeah you will lose oil pressure. Im not sure of any HP or faster reving advantage with not having the belt, (never had an H22 with the shafts) but it must help a little, less drag on the motor.
Old Mar 6, 2003 | 08:44 AM
noslude93's Avatar
satan_srv
You think that I will have engine vibration even with the whole engine balanced.
crank to rods to pistons.
Why would I have any vibration ?
Old Mar 6, 2003 | 10:05 AM
Furry
Guest
Posts: n/a
the balancer shafts are counterweighted and spin at 2X the speed of the engine to counter the vibration inherent in I4 engines. the only reason they put em in there is for us fat americans who hate for things to vibrate the car, same reason they have mushy engine mounts and lots of heavy sound deadning. removing the belt will have about the same effect as putting in the poly ES engine mount inserts and will not cause any harm to the engine. the engine responds like it has a lightened flywheel. frees up around 8-12 hp across the board and allows the engine to rev faster
Old Mar 6, 2003 | 10:20 AM
noslude93's Avatar
Default Re: Balancer shafts.? (Furry)
So if I already have motor mount inserts. Am I realy going to fell this ?
The motor is all balanced?
I dont want it to shake the **** out of me.LOL
Because when I put in the motor mount I thought that it vibrated a lot?
So Am I going to feel that X2?
Old Mar 6, 2003 | 10:40 AM
satan_srv's Avatar
see you don't get it. no matter how balanced your motor is the I4 will create 2nd order vibrations. It's not like the vibrations on the crank.
Old Mar 6, 2003 | 02:54 PM
PUREVIL's Avatar
Default Re: Balancer shafts.? (satan_srv)
If thats teh case why wouldnt teh B series have them ?
They are a I4 ?
Old Mar 6, 2003 | 03:58 PM
slow02ss camaro's Avatar
B16's aren't as big as h22's...the general rule in the auto industry with !4's has been 2.0l and up. Of course some above that 2.0l come from factory without the shafts but most do. I just took my belt off and it vibrates more but the gain is worth it.
Old Mar 6, 2003 | 05:29 PM
noslude93's Avatar
Default Re: Balancer shafts.? (slow94accord)
So in your opinion would you do it if you were me?
How bad is the vibration?
Should I take the poly motor mounts out?
Or will I be able to tolerate it with both in ?
Thank you for the advice every one.
Old Mar 6, 2003 | 08:39 PM
noslude93's Avatar
I would just like some advice so I dont regret what I do.
Can Anyone speek from experience.
MOTOR MOUNTS , NO BALANCER SHAFTS.....
Am I going to regret this...( VIBRATION )
Old Mar 6, 2003 | 09:08 PM
ALTERED4's Avatar
pulled my belt off a couple weeks ago, quite simple, hardest part is removing the crank pulley bolt... cant report any gains since its been well over a month since i last went to the track, the motor does seem to rev a bit easier...
as far as vibration goes, i love it... ive got teins with pillowballs, mount inserts, removed interior, partially removed tar, on top of the removed balancer belt... if you want a smooth cadillac-like ride, dont do it... there is a low rpm buzz-like tone and several new vibrations coming from the dash and the front bumper area... i want to say from the driver's seat, the vibration feels like motor mount inserts x3...
ronqqq
Apr 2, 2008 10:33 AM
whatever210
Mar 5, 2008 12:14 PM
crdcz03
May 1, 2005 08:30 PM
h22wagon
Jul 23, 2003 10:13 AM
The Punisher
Aug 24, 2002 06:00 PM
