swapped the d15b2, but now wont start...any help?
Old Mar 5, 2003 | 03:05 PM
pelotudo's Avatar
Default swapped the d15b2, but now wont start...any help?
We swapped the d15b2 out of my dads Civic, and got it finished last night. We're having trouble getting the new one started though, and wanted to see if you guys could help.
We are getting spark (Tried to check the timing w/ the light, it will flash but not constant enough to get an accurate reading)
Checked the fuel pressure, and we're getting pressure to the front.
It will turn over, but will not fire and just keeps going. What should we check next?
-Jon
Old Mar 5, 2003 | 03:14 PM
Malgerus's Avatar
Default Re: swapped the d15b2, but now wont start...any help? (Unboosted PeloTudo)
Did you put a new timing belt on it and install it a tooth off?
Old Mar 5, 2003 | 03:48 PM
Blaze45's Avatar
Brrraaaap!
Default Re: swapped the d15b2, but now wont start...any help? (Blaze45)
ok im stupid didnt read the first post fully. replace the dizzy with another one and are you getting any ecu codes? sounds like its the ignigtor in the dizzy is gone. maybe im worng if that doesnt help replace the ECU with a diff DX one and c then
Blaze
Old Mar 5, 2003 | 04:13 PM
pelotudo's Avatar
the dizzy is the dizzy off the old engine we had in there, and it worked fine when we took the engine out a couple weeks ago. i'll have to check for codes
Old Mar 5, 2003 | 06:14 PM
my91civic's Avatar
make sure your ground wires are hooked up
Old Mar 6, 2003 | 07:54 AM
stealth civic's Avatar
Default Re: swapped the d15b2, but now wont start...any help? (my91civic)
that gets my vote. Those ground wires to your battery, transmission, and valve cover have to be clean and tight to get the car running.
Old Mar 6, 2003 | 08:23 AM
Speed PHreak's Avatar
Check the grounding wire by the thermostat, its the main ground for your ECU.
dmxbmx
Jun 2, 2010 09:52 AM
airjordan604
Jul 3, 2009 12:24 AM
Schaz
May 4, 2005 11:31 AM
allmotorej8
Oct 12, 2004 10:26 PM
oOPreludeBoyOo
Jul 20, 2003 08:11 AM
