Fuel Pressure reading for stock D16a6?
Old Mar 5, 2003 | 02:37 PM
1.8Tities's Avatar
Default Fuel Pressure reading for stock D16a6?
Do you guys know what is the fuel pressure reading for a stock d16a6 engine? I need the idle reading and WOT reading. Thanks
Old Mar 5, 2003 | 02:39 PM
slowman's Avatar
I took way too long
Default Re: Fuel Pressure reading for stock D16a6? (4thGSi)
for idle, im pretty sure it's 30. i'm just taking this from memory.
Old Mar 5, 2003 | 02:45 PM
G2turbo_terror's Avatar
Default Re: Fuel Pressure reading for stock D16a6? (slowmanEF)
yeah, I'm not positive but I believe its 30/35-7...some one correct me if I'm wrong
Old Mar 5, 2003 | 08:04 PM
sporkcrx's Avatar
Default Re: Fuel Pressure reading for stock D16a6? (G2turbo_terror)
Mine is set at 37psi with the vacuum hose off. Stock settings are 35-40psi with hose off I believe.
Old Mar 6, 2003 | 11:09 AM
crxtreme27's Avatar
at idle, mine is at 30, with the vacuum hose off, its about 38psi...
Old Mar 6, 2003 | 11:18 AM
zCivic's Avatar
Default Re: Fuel Pressure reading for stock D16a6? (crxtreme27)
36-38 normally with vacumn off. When you read/hear pressures its always assuming the vac is unhooked.
[Modified by zCivic, 3:19 PM 3/6/2003]
afnan
Jan 12, 2014 05:16 AM
sixtodc2
Nov 7, 2007 08:27 AM
3rdGteg
Oct 25, 2002 09:21 AM
See Are X
Oct 19, 2002 07:17 PM
1bar
Sep 10, 2002 09:37 AM
