what do u guys think of thes gearing on a y1
Old Mar 5, 2003 | 10:58 AM
NightHawkC5's Avatar
Default what do u guys think of thes gearing on a y1
just windering peoples thoughts and comments on the specs on it. Its for a crv-tec setup
Old Mar 5, 2003 | 11:35 AM
joe_bocc's Avatar
Default Re: what do u guys think of thes gearing on a y1 (NightHawkC5)
The gearing on the Y1 is kind of tall
Old Mar 5, 2003 | 03:29 PM
Default Re: what do u guys think of thes gearing on a y1 (joe_bocc)
really tall like ls tall
Old Mar 5, 2003 | 04:46 PM
joe_bocc's Avatar
The Y1 is taller than the LS transmission in all gears, but first.
Y1 S1/YS1 from 90-93 LS
3.166 3.230
2.052 1.900
1.416 1.269
1.103 0.966
0.870 0.742
Seeing as they both have the same final drive, the gearing on the Y1 is taller than an already considered tall transmission (LS).
Old Mar 5, 2003 | 05:17 PM
Patch's Avatar
Its really not that bad. I have a Y1, my friend has a S1 in his hatch. Running right beside eachother, we still shift at about the same places. Either one is fine, its not too tall at all.
Old Mar 5, 2003 | 05:44 PM
Default Re: what do u guys think of thes gearing on a y1 (CRX PAT)
so i wont be spending to much time in each gear?
Old Mar 6, 2003 | 03:55 AM
Patch's Avatar
Hell no! With a y1 you shift just as quick as an s1. Its really not noticeable at all.
Old Mar 6, 2003 | 04:38 AM
Bontke's Avatar
Uhhh...is it me or does it seem that the Y1 has a better gear selection than the LS trans. Do the math. When you multiply the final drive ratio times the selected gear you get a number. That number, the higher it is, means the RPM will be higher in that gear. THere is another formula for that but I have forgot it. It looks like the real lead for the YS1 is first and every gear after that for the Y1 keeps the engine in a higher RPM than the YS1.
Old Mar 6, 2003 | 06:45 AM
ricodemus's Avatar
3.166 3.230
2.052 1.900
1.416 1.269
1.103 0.966
0.870 0.742
the higher the number, the shorter the gearing. The y1 is geared for acceleration better than the LS.
Old Mar 6, 2003 | 02:37 PM
Default Re: what do u guys think of thes gearing on a y1 (ricodemus)
is the y1 better than a j1
Old Mar 6, 2003 | 02:44 PM
Patch's Avatar
No, the J1 and the S1 are the same transmissions.
Old Mar 6, 2003 | 04:02 PM
Bontke's Avatar
Dude....what kinda crack are you on? They are far from the same. So what do you base your argument on saying the transmissions are the same?
Old Mar 6, 2003 | 04:20 PM
MikeSarr_GSR's Avatar
Default Re: what do u guys think of thes gearing on a y1 (Bontke)
3.166 3.230
2.052 1.900
1.416 1.269
1.103 0.966
0.870 0.742
ITR is
3.23
2.104
1.458
1.104
0.848
4.400
do the math the Y1 is great freaking gearing just change the final gear.
Old Mar 6, 2003 | 04:24 PM
bryant's Avatar
uh what crack are you on? He said the J1 and S1 are the same. And they are. The Y1 has way longer gears then the JDM YS1/S1/J1.
EDIT: To go with the original topic at hand, the Y1 is a good tranny for daily use. Has good gears for daily driving and still good gas milage. Would work well with turbo use too.
[Modified by Bryant, 6:24 PM 3/6/2003]
Old Mar 6, 2003 | 05:42 PM
Patch's Avatar
You, sir, are a dumbass. Go on any website with specs on Honda transmissions and they are exactly the same. The only difference between them was that they came in different cars. One was in a CRX and the other in an Integra I beleive. I actually know what I'm talking about instead of talking straight out of my ***.
Old Mar 6, 2003 | 07:43 PM
i have a y1 with lsd and got it for giving a guy my j1 i want to know how bad are the y1's gears compared to the j1 and i hope to put the lsd in the j1 if it is that bad. someone told me all u have to do is change the countershaft with it which means ill have the y1 1st gear but the j1's 2nd +
and a b20 crank
[Modified by NightHawkC5, 4:43 AM 3/7/2003]
Old Mar 7, 2003 | 01:43 AM
bump
Old Mar 7, 2003 | 04:16 AM
ricodemus's Avatar
Well, the j1 has very short gears and I will tell you this from experience: You do not want the y1 1st gear, that thing is so tall. It's hard to get a good 60 ft. You should be able to mix and match parts though.
Old Mar 7, 2003 | 06:10 AM
Bontke's Avatar
My bad, I am the crack smoker. Nothing like "hitting the pipe" before you post. Anyone got a light bulb? I thought the Y1and S1 were being compared.
Old Mar 7, 2003 | 09:16 AM
so what do u guys think of what i plan to do with the 2 trannys
Old Mar 7, 2003 | 09:40 AM
ricodemus's Avatar
It depends on what you are using the car for. If it is a highway driven car, but you are also racing it, I would put the y1 5th gear in the j1. The j1 is at really high rpm when on the highway. Otherwise, I believe the j1 is a great trans as far as racing is concerned.
Old Mar 7, 2003 | 09:49 PM
ttt
Old Mar 8, 2003 | 03:46 AM
Patch's Avatar
I think you should sell me the J1 and keep the LSD Y1
Old Mar 9, 2003 | 02:35 PM
Bontke's Avatar
I don't think that 5th gear matters at all. If you are using it for racing you probably won't even use 5th. I have both a Y1 and J1 and the difference in fifth is barely noticable. My gas mileage didn't even change. When you are in 5th trying to make power you have to overcome wind resistance more than gearing.
Stopsign32v
Aug 8, 2019 05:44 AM
purplerain11
Jun 19, 2013 05:34 AM
a1320honda
Transmission & Drivetrain
May 21, 2013 09:11 AM
WWDTrackRacer
Sep 11, 2007 10:36 AM
