camber kits?
Old Mar 5, 2003 | 10:58 AM
DOHCRX's Avatar
Default camber kits?
Do you think i wil need one on my 91 crx si?? i lowerd it 2 inches with some dropzones. Any advice? thanks
Old Mar 5, 2003 | 11:11 AM
xvracing's Avatar
Default Re: camber kits? (williamsCRX)
You probably dont have to bad of negative camber, and you might be able to fix it without a camber kit, but if you have money for it. If you have expensive tires, i would suggest it because you dont want to waste money buying tires if they only last 10,000 miles. it really sucks when half of your tire looks new and the other half is bald.
Old Mar 5, 2003 | 12:43 PM
Ef Whore's Avatar
Default Re: camber kits? (xvracing)
I'm rocking about 5 degrees negative. I say the hell with camber kits.
Old Mar 5, 2003 | 12:45 PM
DOHCRX's Avatar
Default Re: camber kits? (Ef *****)
i think i might just say the hell with it then lol..thanks
Old Mar 5, 2003 | 02:29 PM
Aron Parsons's Avatar
Negative camber doesn't effect tire wear nearly as much as your toe settings. 2" isn't going to significantly decrease the life of your tires as opposed to having 1/8" toe-out on each side. Have a good alignment done, and that's all you should need. Anything past 2" is pushing it though, and a camber kit might be necessary.
Old Mar 5, 2003 | 04:36 PM
one slow d16's Avatar
say the hell with traction during a launch too
89MA70
Suspension & Brakes
Aug 11, 2008 01:01 PM
3Rd GeAr PuLl
Feb 2, 2007 05:32 AM
E36 Guy
16
Apr 7, 2006 09:58 AM
defaced
Feb 10, 2004 05:47 AM
spork sport
19
Mar 12, 2002 09:02 PM
