4DR axle back same as 2DR???
Old Mar 5, 2003 | 10:21 AM
JSPEC4DR's Avatar
Default 4DR axle back same as 2DR???
Is the axle back part of the exuast same on 4doors and 2doors? cause I know the cat-backs are . But I am pretty sure the axle backs are the same. Cause when u go and buy a axle back exaust all is says is 94-01 Integra. doesnt matter if its 2 or 4 door right??? but cat-backs say specifically for 4dr or 2dr.
Will an axle back exuast fit on my 4 door thats all that matters??
Thanks.
Old Mar 5, 2003 | 10:53 AM
daewonder.'s Avatar
Default Re: 4DR axle back same as 2DR??? (JSPEC4DR)
I've done a lot of research on this too. Chances are it will fit. But depending on the muffler, it will probably be short and sit under the bumper. Not a huge problem.
However, I'm running a Greddy SP for a coupe on my sedan, and now my bumper is melting. Be careful.
Old Mar 5, 2003 | 11:04 AM
JSPEC4DR's Avatar
so are u saying the mid section is almost the same too? u have a 2dr cat-back on ur 4DR??? and it fits??
Old Mar 5, 2003 | 11:07 AM
JSPEC4DR's Avatar
I got a good deal right now on a DC sports cat-back but its for a 2DR. Cant get the same deal on the 4DR one cause they have the 2DR exaust in stock.
If I buy it will it fit my 4DR? cant I just go to a muffler shop and extend the pipe if it sticks in further.
Thanks.
Old Mar 5, 2003 | 11:09 AM
emr88's Avatar
I recently bought a axle back RS*R section from Turbo Imports for my 4dr and although it's designed for a 2dr, it's the same length as my OEM axle back. This leads me to believe that as far as RS*R catbacks are concerned (other manufacturers may be different) the midpipe is different, but the axle backs are the same.
Old Mar 5, 2003 | 12:55 PM
daewonder.'s Avatar
Default Re: 4DR axle back same as 2DR??? (emr88)
I had to extend my pipe about 4-5 inches.
Old Mar 5, 2003 | 03:46 PM
illi Adik's Avatar
Normal exhausts will be shorter for the 2dr. I know OEM is at least because I had to swap on my buddies axel back from his 2dr to pass an exhaust citation and it sat under the bumper.
Old Mar 6, 2003 | 04:40 PM
94gsrsedan's Avatar
i think the 4 door is 3 inches longer
94 high 13sec gsr sedan
many mods
Old Mar 6, 2003 | 05:05 PM
Westrock2000's Avatar
Default Re: 4DR axle back same as 2DR??? (94gsrsedan)
It sucks because alot less choices are out there for the 4 door, and sometimes there more expensive. So it would be nice to know. I'll probably just buy a 2 door and if needed get it extended.
Old Mar 6, 2003 | 05:49 PM
MachAF's Avatar
Default Re: 4DR axle back same as 2DR??? (Westrock2000)
I'm running 2dr RSR on my 4dr. Works fine. Tip is tucked in 2 inches.
Old Mar 6, 2003 | 06:24 PM
JSPEC4DR's Avatar
is it just the axle back or complete exaust!
I wanna know if I buy a 2DR cat-back will it fit my 4DR????????
ANYONE KNOW???
Thanks.
ozh_hawaiian
Sep 24, 2011 09:14 PM
easybake
Nov 25, 2008 07:48 AM
white98gs-r
Sep 6, 2008 01:27 PM
daewonder.
Feb 17, 2003 02:15 PM
typerlover
Jan 27, 2002 11:25 AM
