ECU Question
Old Mar 5, 2003 | 09:21 AM
P18AJ79's Avatar
Default ECU Question
I am looking for the Speed output on my ecu (99civic EX ) D16Y8 can any one post up a diagram with all the pins thanks
Old Mar 5, 2003 | 09:29 AM
Kataku2K3's Avatar
Default Re: ECU Question (P18AJ79)
Damn I could tell give you that for a nonOBD, OBD1, and OBD2a ECU but I don't have them for OBD2b... I assumed that the pinouts are different but the OBD2a one is C18... (It could be I guess since your car runs plugs A,B,C) If you can't find out then I would just trace the wire from the VSS to the ECU via continuity testing, just make sure you are looking at the signal wire... I just haven't worked on that many 99+ Civic's to need them I guess... If I can find anything OBD2b I'll let you know but if you get them you wanna let me know too... haha.... Peace
Old Mar 5, 2003 | 11:03 AM
P18AJ79's Avatar
Default Re: ECU Question (Kataku2K3)
thanks for the help i have the diagram at the shop i totaly forgot about it. thanks again
Techy
Apr 22, 2007 02:32 AM
Inkrazy
Mar 7, 2004 10:22 PM
