Need help with HASport linkage...
Old Mar 5, 2003 | 07:18 AM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Need help with HASport linkage...
Im putting all of the stuff from my stock linkage onto my HASport linkage and it al fits except the bushing on the block end of the stabilizer bar. Its way too small...i guess that i have to buy one. What do i need to buy? I think that they could have told me that id have to buy something else...now its just putting off my swap longer. Thanks
sean
Old Mar 5, 2003 | 07:50 AM
Rspec CX's Avatar
Default Re: Need help with HASport linkage... (sCeRaXn)
You can use any linkage bushing for a 90-2000 integra...I got an ES bushing kit for mine and it worked perfect....you will also need two dished washer type things that go on each side of the rubber bushing that I am yet to find since I dont have an acura dealership anywhere near me...if anyone can get me these parts let me know...thanks
Old Mar 5, 2003 | 08:53 AM
stealth civic's Avatar
Default Re: Need help with HASport linkage... (88sirhatch)
http://www.acuraautomotiveparts.org
They are a great source for factory parts, just get the integra bushing. When I put my linkage on, i didnt have a bushing either. I took an old oil cap, put electrical tape around the threads till it fit in the bushing hjole, drilled a hole through the center for the bolt, and put washers on each side. it worked just as well as the actual bushing. Drove my car for a week like that.
Old Mar 7, 2003 | 01:26 AM
HandCommand's Avatar
Here's what you will need:
The Bushing: 54303-SB2-010
Flat Silver Washer: 54305-SAO-000
Beveled Black Washer: 543-SK7-000
12mm Bolt: 95701-0801808
The main thing is the bushing and maybe the beveled washer. The other stuff you can find around the shop/garage.
I think the main reason why HaSport doesnt include all this hardware is because usually you can find it on the cut linkage of the JDM tranny.
I agree though that they should inform the buyer that they may need to get these items if their swap didnt come with them.
I keep some extra sets of this hardware package on hand, just in case the tranny doesnt come with them.
hondata760
May 17, 2013 09:38 AM
hellracer24
14
Jan 17, 2007 04:16 PM
allmtrdc4
17
Feb 7, 2005 07:59 AM
