head gasket
Old Mar 5, 2003 | 03:54 AM
HATCHFREEK's Avatar
Default head gasket
what are the common clues on the car that tell you that you blew your head gasket.>....help me out guys, thanks
[Modified by HATCHFREEK, 1:10 PM 3/5/2003]
Old Mar 5, 2003 | 04:32 AM
HATCHFREEK's Avatar
Default Re: head gasket (HATCHFREEK)
anyone know?
Old Mar 5, 2003 | 04:44 AM
Tony Starks's Avatar
Pull the dipstick and see if there is a whitish liquid on the stick.
Old Mar 5, 2003 | 04:51 AM
HATCHFREEK's Avatar
Default Re: head gasket (Tony Starks)
there is a bit... oil does seem a bit lighter than brownish..
Old Mar 5, 2003 | 05:30 AM
White Lightnin's Avatar
Is there white smokle exiting your exhaust?
Also, You can take off your radiator cap and then try to crank the car. If it bubbles you probably have blown a gasket.
Discalimer: Not sure on above procedure. Just what I remember reading. Pretty sure it is right.
Old Mar 5, 2003 | 05:41 AM
HATCHFREEK's Avatar
Default Re: head gasket (White Lightnin)
dude im not sure if that could be it.. i tried it, i had the car running revved the engine and it bubbled a bit... but then again i think i have too much oil in the motor... i kinda over did it before... it wayyyyyyy over the max line.. u think that could be the problem?
MikesBB4
Apr 9, 2012 10:17 PM
jdm12345
May 31, 2007 05:52 PM
Trellis
Sep 18, 2004 07:58 PM
Mr. Thunderlips
Nov 8, 2002 05:25 PM
