HELP!!! partially built b20b ????
Old Mar 4, 2003 | 07:00 PM
JDM_Risa's Avatar
Default HELP!!! partially built b20b ????
my friend has a partially built integra....and we were wandering how much hp would this set-up produce....and estimated quarter mile time......its in a 94 integra ls....
its a
B20B
head consist of
Crower 62403s
Crower valve springs and retainer
AEM cam gears
milled .006
stage 2 MILD port and polish
stock intake manifold port match to the TB
AEM short ram
DC sport 4-2-1 header
Custom 2.25 piping onto a Greddy SP canister
Stage 1 clutchmaster clutch
STOCK bottom end!!!!
stock ECU program...do u think its safe to rev past 7k or shud my friend say @7k rpm redline to be safe.....the guy who built the motor is he could take to 7800-8000 if he wants...the bottom block will just keep spinnin... this sounds a little risky...
info will be apprecaited...
will a great amount of hp be gained by raising the redline....if so how much possibly?
Old Mar 4, 2003 | 08:27 PM
LsPower's Avatar
Default Re: HELP!!! partially built b20b ???? (GunMETAL_TEgRa)
With those cams it will make power untill a little over 7000 I believe. It should probably be safe to rev a little higher but if you have a stock ecu then the rev limiter should kick in at 7000.
97uswagon
May 9, 2013 12:07 AM
petergriffen
Feb 1, 2006 05:29 PM
lv6l
27
Sep 13, 2005 11:27 AM
LilChuck
Mar 5, 2005 03:33 PM
InspiredRacer
Aug 17, 2003 11:15 PM
