Rsr header has no o2 bung, what do i do?
Old Mar 4, 2003 | 06:58 PM
AirWaveGT's Avatar
Default Rsr header has no o2 bung, what do i do?
I have a 97 gsr and i just got a rsr header for it. The only problem is that the header doesnt have an o2 bung to put the o2 sensor in. What can i do so this wont be a problem? Could i just gen a hi-flow cat and have 2 bungs on it or would i have to have one put on my header?
Old Mar 4, 2003 | 07:01 PM
94TealGSR's Avatar
Default Re: Rsr header has no o2 bung, what do i do? (AirWaveGT)
Just take it to a muffler shop and have them cut a hole then weld one on. Not sure on the cost, but if it were $50+ i'd be surprised.
Old Mar 4, 2003 | 07:11 PM
AirWaveGT's Avatar
i was planning on buying a hi-flow cat soon, so would it be easier/cheaper to have 2 bungs put onto the cat instead of having it welded into the header or would that even work?
Old Mar 4, 2003 | 07:47 PM
MachAF's Avatar
According to my helms manual, both the primary and secondary o2 sensors are in the catalytic converter on B18c1 engine. And b18b1 the primary is in the header.
So the RSR header should work fine.
i have a 97 GSR, but i havn't looked under it to see exactly where the o2's senors are, but I trust the helms manual.
Old Mar 4, 2003 | 07:53 PM
AirWaveGT's Avatar
Default Re: Rsr header has no o2 bung, what do i do? (machaf)
thats good to hear that i wont have to go through the trouble. I havent checked it yet either, i just assumed one was in the header. thanks for the info, if it is correct i should have the header in my car tomorrow.
Old Mar 4, 2003 | 08:42 PM
Rory Breaker's Avatar
There is no bung in the header for a 94-99 GSR, it will bolt right up.
blueintegra90
Sep 5, 2003 07:18 AM
Bman
Aug 27, 2003 04:42 PM
92SiHatchie
Jul 22, 2003 08:33 PM
ichibano
Mar 15, 2003 04:04 PM
2k1TypeR0610
Mar 25, 2002 04:26 AM
