Fuel Injectors size??
Old Mar 4, 2003 | 05:33 PM
bobby913's Avatar
Default Fuel Injectors size??
Hi guys, well, I'm going N/A in my prelude, and now I want to upgrade my fuel Injectors. The stock injector size are 280cc saturated. My friend told me to go with 310cc. But I think thats just too little on increase. Should I go 370cc? Please help out.
PS - I road race so I don't know if there's a difference in a drag car and a road race car.
Old Mar 4, 2003 | 06:14 PM
Anubyss's Avatar
Default Re: Fuel Injectors size?? (bobby913)
97+ Preludes have 290cc injectors. It runs rich to begin with so unless you are doing some serious mods, you don't need to upgrade them. The problem with bigger injectors is you need to buy something to control them. Either a vafc or some sort of engine management sytem. What year is your Prelude (I am assuming 97+) and what do you plan on doing to the engine?
Old Mar 4, 2003 | 06:33 PM
bobby913's Avatar
Default Re: Fuel Injectors size?? (Anubyss)
Well, first of all, I have a 99 type SH. I got FPR, VAFC, 255LPH fuel pump, and a jun chipped ecu. Now, im running lean cuz i can hear the lean pop when i shift. I plan on gettin the whole 9 yards on engine parts. But I'm gettin the fuel injectors this week, and i don't want to switch them to higher ones, after i bought these so i just want to make sure which one is the best for N/A.
Old Mar 4, 2003 | 06:43 PM
Cottonwoodz's Avatar
Explain, this Lean pop....Wheres it coming from, this lean pop??
Old Mar 4, 2003 | 06:46 PM
RAB's Avatar
RAB
Default Re: Fuel Injectors size?? (Cottonwoodz)
Finally and good topic of discussion. I in the process of controlling my fuel and I need to know what to get. I think and FPR along with a VAFC would be great. I need to learn so post away please.
Old Mar 4, 2003 | 07:22 PM
bobby913's Avatar
Default Re: Fuel Injectors size?? (RY8127)
Well, about this lean pop, I think its because I hollowed my cat, and the ecu I changed. When I shift, I did shift at a high rpm(@8500-8600, it was recorded on the VAFC). So I guess the lean pop comes out of the exhaust cuz when I went to track last time, my friend behind me said he saw blue and black smoke when i up/down shift.
Old Mar 4, 2003 | 07:27 PM
Boostless97Lude
Guest
Posts: n/a
yeah, some nive 370s would be great.... *cough*look-in-sig*cough*
4bidden's Avatar
The lean pop is most likely a rich pop, lol. Unburnt fuel exploding on its way out the exhaust. The hollow cat causes this also.
Shifting at 8500-8600 will cause lots of pops, including your motor.
Old Mar 4, 2003 | 07:28 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: Fuel Injectors size?? (4bidden)
revving it to 10grand wil also shoot a major ****** flame out the tailpipe
Old Mar 4, 2003 | 07:40 PM
bobby913's Avatar
Default Re: Fuel Injectors size?? (Busted97Lude)
I mean, I don't rev it that high every time, but when i go to track it goes that high because of the downshift, and i need to stay on vtec cuz vtec kicks in at 5800(its the ecu/clutch is slippin also/haven't tune or lower the vtec engagement). I plan on getting all the parts for the head so i can safely rev that high.
**When I change my spark plugs last week, the mechanic says 2 of the plugs looks lean. And I did raise my Fuel pressure by 4 psi before that happened.
Back to the point guys. What size for FULL ROAD RACING?
[Modified by bobby913, 5:38 AM 3/5/2003]
6GACCORDH22's Avatar
lol , big ****** flames
One Slow Lude's Avatar
So what kinda of NA mods can you get away with on stock injectors (cams, higher compression pistons?) I recently decided im probably going this way (damn atts cutting out w/ boost) so just wondering for reference....thanks
EDIT: btw, boosted what did you do to your car, if you dont mind me asking....?
[Modified by POSlude97, 11:42 PM 3/4/2003]
Old Mar 4, 2003 | 07:43 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: Fuel Injectors size?? (98cpturbo)
i swear dude.. iw as running the automap on my AEM EMS the other night, and my friend was standing outside the car, and i was revving it up, and BOOM, ****** flames shot out BOTH mufflers, it was ****** CRAZY, the whole area lit up and my friend jump a mile in the damn air....
Old Mar 4, 2003 | 07:47 PM
next time get pics
<U>BOOM, ****** flames shot out BOTH mufflers, it was ****** CRAZY, the whole area lit up and my friend jump a mile in the damn air....
</U>
[Modified by 98cpturbo, 11:49 PM 3/4/2003]
Old Mar 4, 2003 | 07:49 PM
Boostless97Lude
Guest
Posts: n/a
oh, i will definately try...... i'll of course have someone else take the pic, with no rev limiter, i wouldn't wnat any of my goofy *** friends to over rev the bitch.... then again, they'd probably all be to scared to rev my car up for fear of an *** whooping they'd get if the blew my motor
Old Mar 4, 2003 | 07:50 PM
Boostless97Lude
Guest
Posts: n/a
next time get pics
</U>
somehow i get the idea you don't believe me
Old Mar 4, 2003 | 07:53 PM
i do , would be a cool pic
Old Mar 4, 2003 | 08:20 PM
DsITR's Avatar
Default Re: Fuel Injectors size?? (POSlude97)
I should prolly leave this to Sam or some other Motor guru. But Ill stab it yO!
Basically our cars run rich from the factory @WOT... so injectors are only neccessary if..
1.Boost, Nitrous, raised cr...(ie, preventing detonation..the extra fuel compensates for the extra air.)
2.If your car is currently running lean and you need more fuel to make extra power.
(bear in mind there is an optimal mix..like 14:1 air/fuel. I can't remember the exact ratio. So running too lean or too rich can cost power and reliability.)
So..cams you should be fine..You can still add more fuel w/the stock injectors w/the V-afc, to compensate for the extra air.
Comp Ratio on the other hand...I think you would be fine unless you go extreme like 12:1 or higher.
Boost...I have *heard* (I am no turbo guru.) 7psi you can be ok...anymore you need some type of tuning..(then you run into other problems like internals.)
Anyone else back me up on this?
Old Mar 4, 2003 | 09:34 PM
Jeff33S's Avatar
I dont think you need bigger injectors sounds like what you need is just some tuning.
-Jeff-
Old Mar 5, 2003 | 03:19 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: Fuel Injectors size?? (Jeff33S)
sounds good to me D.
Old Mar 5, 2003 | 04:49 AM
lildrgn2.0's Avatar
New User
I shoot flames.. Stunna Ben saw them when I was racing (destroying) the blue SI he was driving. .. he said it looked nice .. HA..
and the pop is from being rich..
you can hear it in every one of my racing vids.
I pop all the time..
Old Mar 5, 2003 | 11:09 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: Fuel Injectors size?? (Lildrgn)
why the **** didn't he roll the GS-T???? i meant to ask im, but i forgot
BTW Mike, i didn't expect you to actually be "little"
Old Mar 5, 2003 | 12:06 PM
Furry
Guest
Posts: n/a
i was shooting flames out of my accord, jdm h22a, i/h/e/msd/vafc, no cat, 2.5 inch from the header back
Old Mar 5, 2003 | 10:32 PM
bobby913's Avatar
Default Re: Fuel Injectors size?? (Furry)
Thanks guys, I'll dyno tune my car once I get it out of the shop.
Old Mar 6, 2003 | 11:51 AM
NXLude's Avatar
Yeah, Id fiddle with what you got before you get bigger stuff....like it was said, without higher cr or boost you will be fine on stockers.
Briyumbero
Nov 13, 2008 05:24 AM
nd94cx
Oct 11, 2004 03:05 PM
m1ndphz3r
Feb 20, 2004 09:52 AM
Propulsion
Dec 17, 2003 08:39 AM
RTW DC2R
May 24, 2002 06:54 AM
