Politely requesting a Turbo b20 hondata tune
Old Mar 4, 2003 | 02:12 PM
Will Albers's Avatar
Default Politely requesting a Turbo b20 hondata tune
Wow, reading this again, my post made zero sense. Must have drank too much NyQuil.
Anyways, I have a Jap spec b20b motor. It has been sleeved and introduced to new Eagle rods and Arias 9.3:1 dished pistons. The head is a stock LS head with a fresh 3 angle valve job.
I am running a greddy 15g turbo, intercooled. Fuel is supplied via 450cc injectors and a walbro pump at a steady 41 lbs of fuel pressure at idle.
Now does anyone have a base b20 Hondata or Zdyne map? Something that I can use as a FOUNDATION for building my own Zdyne tune? I realize i will need to modify it for my specific add-ons, but I would like to use something besides a LS tune +20% fuel.
Any and all help appreciated.
Modified by Will Albers at 10:30 PM 6/27/2004
Old Mar 5, 2003 | 06:13 AM
Default Re: Politely requesting a Turbo b20 hondata tune (Will Albers)
ttt
Old Mar 5, 2003 | 06:17 AM
Charlie Moua's Avatar
WTF are you asking?
are you looking for... base hondata maps for a b20 turbo? what turbo?
Old Mar 5, 2003 | 07:18 AM
prophet's Avatar
injector sizes, fuel pressure, etc sure would help some of the people that can help u =P
Old Mar 5, 2003 | 08:28 AM
sgT's Avatar
sgT
I can always make you an impromtu street tune
Old Mar 5, 2003 | 10:01 AM
TurboInteg95's Avatar
I can give you my map if youd like but I can almost guarantee it wont be perfect for your setup. Unless at the very least you happen to have the exact same turbo as me but that is highly unlikely. lemme know if you want it. It is setup for 550 cc injectors. It put down 250 hp and 225 ft lbs on 7 psi on a Japanese B20b motor. I highly suggest against doing this though.
Old Jun 20, 2004 | 01:20 PM
Default Re: Politely requesting a Turbo b20 hondata tune (TurboInteg95)
Old Jun 27, 2004 | 06:30 PM
Old Jul 1, 2004 | 07:23 AM
tt
Old Jul 1, 2004 | 07:37 AM
ITRpwrdEG's Avatar
Default Re: (Will Albers)
Ok, I think the first two guys that posted after your original post are morons. No, it's not worded wrong. Quit giving the guy a hard time. What needs to be asked is what kind of hondata he is running. Because you need a chip based on the S200, S100, etc. and Yes, he did mention what injector size, fuel pressure, and if you would have read it, you would have seen 15g. So of course he WANTS A BASE MAP. The only thing he could have added was if they are peak and hold or saturated, which im sure they are peak and hold. Can't remember if he said DSM's, but if so, then he did mention right there that they are peak and hold.
To be honest, any base map should get you where u want. I would look for one from a smaller Garret or Turbonetics turbo setup. Like a super60 or straight t3 for that matter. May be a little bigger than a 15g, but its close.
Keep on the Nyquil. Your **** makes perfect sense. Don't let these guys fool u makin you look like more of an A@@.
And sorry, I don't have a basemap, just dustin these fools off ur shoulders. Good Luck.
riceracer07
Mar 5, 2007 04:15 PM
sdr KEL
Aug 1, 2005 10:28 PM
Will Albers
Feb 21, 2003 05:18 PM
battyx
Mar 25, 2002 08:11 PM
DSF
Feb 6, 2002 06:35 AM
