Spring/Shock Install
Old Mar 4, 2003 | 01:37 PM
Accord2K1's Avatar
New User
Default Spring/Shock Install
I just got Tokico Illuminas and H&R Sports. I'm trying to find out what a reasonable price is to have them installed. A local tire shop where I live said they could do it including an alignment for around $400!!!! I was like WTF! So, I called a few places in Tampa, which is like an hour away and the quotes I got were around $130 - $150 without the alignment. Is this reasonable?
Old Mar 4, 2003 | 01:40 PM
carolinaACCORD's Avatar
Default Re: Spring/Shock Install (Accord2K1)
around here it's around $40/hour for the spring/shock install (shouldnt take over 2 hours for a experienced mechanic) and about $50 for a 4-wheel alignment. you can expect somewhere around that.
Old Mar 4, 2003 | 01:50 PM
ForcedAccord's Avatar
Texas B*tch!
Default Re: Spring/Shock Install (carolinaACCORD)
Just do the install yourself man. Set aside some time, get the right tools, get a manual, and an extra pair of hands.
You'll learn a lot about your car, it's a good learning experience.
Old Mar 4, 2003 | 01:58 PM
Accord2K1's Avatar
New User
Default Re: Spring/Shock Install (ForcedAccord)
I was thinking about trying that. But, honestly i'm not that good at stuff like this. So, i'm not sure if I should try it. I dont wanna mess anything up.
Old Mar 4, 2003 | 02:55 PM
Texas B*tch!
Get someone somewhat mecanically inclined but do the work yourself.
As long as you follow the manual you can't go wrong, I did it.
Old Mar 4, 2003 | 03:28 PM
TypeSH's Avatar
not hard... look for someone locally w/ experience who is willing ot help you out for like lunch in return or something. Not hard at all, but an extra experienced hand is always helpful
Old Mar 4, 2003 | 06:28 PM
gogeeta13's Avatar
Default Re: Spring/Shock Install (TypeSH)
just watch it with the spring compressors. When I was compressing my stock springs to get them off and install my coilovers, they would periodically pop off the springs. Its very dangerouse because if the compressor broke off and flew into yoru chest, it would probably kill you.
Old Mar 4, 2003 | 06:36 PM
3700 Vtec's Avatar
Default Re: Spring/Shock Install (gogeeta13)
It helps to have someone around that has done it before.
Be careful with taking off the compressed stock springs, don't use a cheap *** spring compressor. If your experienced with this, it can be done without a compressor.
Old Mar 4, 2003 | 08:03 PM
import palace's Avatar
you should be able to find a performance shop in town that will do it for a decent rate 400 w/ and alignement is bull **** just find a performance shop and the should charge you any more than 150.00 for the install and take the car after about a week or so to get it aligned wait that long so the springs can settle in place and an alignment if about 50.00 with a coupon.
Old Mar 4, 2003 | 09:58 PM
One2chi's Avatar
Default Re: Spring/Shock Install (import palace perf)
try doing it yourself but make sure you get a spring compressor (either buy one from an auto parts store for like $11) or i think autozone lends them
Old Mar 5, 2003 | 05:21 AM
Accord2K1's Avatar
New User
Yeah...i'm gonna most likely still take it into a performance shop to have it done. So, is it not a good idea to have the alignment done right away? Could anything go wrong if i wait to get the alignment?
Old Mar 5, 2003 | 09:30 AM
h22accordvtec's Avatar
If its a performance shop it will probably take them about an hour and shouldn't cost you more then $80 bucks. If they charge you more then that they are ripping you off.
Old Mar 5, 2003 | 11:52 AM
Texas B*tch!
Default Re: Spring/Shock Install (h22accordvtec)
Well the alignment probably won't reset your camber back to zero. They will just get your castor and toe back in line which is just as important if not more important than the camber. You're going to need to purchase a camber kit in order to get it back to the original point. If not chances are they will just reset it back within 1 degree or so depending how big of a drop you have.
Old Mar 5, 2003 | 01:43 PM
Utilitarian's Avatar
Plus, you can rent compressors from some parts stores.
Old Mar 5, 2003 | 05:53 PM
Nick H's Avatar
New User
Default Re: Spring/Shock Install (BlackeR2000)
do the install yourself...it's so easy, unbelievably easy actually...there is nothing that you can do to mess anything up...well i take that back:
if you put the damn rear sleeves in the front that happens...whoops...anyways, it's really easy to do yourself...you should do it, there's nothing that can go wrong!
Old Mar 6, 2003 | 05:58 AM
immalooser's Avatar
Default Re: Spring/Shock Install (Nick H)
LOL, how is that possible? The rear springs can't go in the front...can they? The perch on the shock is smaller on the front than it is on the rear
Old Mar 6, 2003 | 10:23 AM
Nick H's Avatar
New User
Default Re: Spring/Shock Install (immalooser)
ground control coilovers, sleeves were mixed up...whoops, but that's what happens...
Old Mar 6, 2003 | 10:55 AM
iam7head's Avatar
LOL, boated accord!
The shop i did my set up charged me 40 bucks..
Old Mar 6, 2003 | 05:35 PM
SiK AcC0rD's Avatar
hey nick what happened to your accord?
-James
Old Mar 6, 2003 | 06:06 PM
Nick H's Avatar
New User
Default Re: Spring/Shock Install (SiK AcC0rD)
welppp....it started with some sand, then some understear, then more understear, then a guardrail, holy **** i'm rolling the car on it's side, blacked out from hitting my head somewhere, then came to and the motor was revving helaciously and i was at the bottom of a ravine...a tree ended up int here somewhere...
brand new carbon fiber hood, smashed!
yeah, well that's the story...sorry for the hijacked thread...
Old Mar 6, 2003 | 10:21 PM
SiK AcC0rD's Avatar
OMigod, i hope u're doing fine. hehe thats a funny drawing LOL, damn that sux about ur accord u did some major damage, to ur car and that gaurdrail!!
Old Mar 7, 2003 | 08:35 PM
Nick H's Avatar
New User
yeah, fortunately i didn't have to pay for the guardrail...i guess three cars went down that ravine that day...i was the second...they made the guy who went down first pay for the guardrail...
Old Mar 7, 2003 | 09:06 PM
PUREVIL's Avatar
holy **** whaa?
Old Mar 8, 2003 | 08:20 AM
jweller's Avatar
wait a minute. they make you pay for a guardrail if you hit it? you've got to be joking right.
anyway, glad you're OK
Old Mar 8, 2003 | 05:26 PM
Nick H's Avatar
New User
Default Re: Spring/Shock Install (jweller)
yeah, it's about $1500 to replace a guardrail...expensive ****...gotta make someone pay for it, i'm just glad it wasn't me who had to do it...
