Is spark racing REALLY warrantying their manifolds???
Old Mar 4, 2003 | 10:44 AM
Full-Race Geoff's Avatar
Default Is spark racing REALLY warrantying their manifolds???
or do they only warranty the manifolds after someone posts all over the internet?
Someone recently emailed me this:
I got my turbo kit and I have a t-60 turbo on it and the 1rst and 4th runners have a hairline crack in the welds on the top of the runners. I am going to have to get the cracks welded but am wondering if you have any ideas on supporting the turbo for weight purposes. The manifold has small "tabs" on the bottom of the runners, are these to help support, the only thing is when I called spark racing they told me that it wasnt designed to hold the weight of the t-60.
now that is just wrong. i hope spark will remedy this, there is no reason they should not take care of this guy!
[Modified by FFgeoff, 2:45 PM 3/4/2003]
Old Mar 4, 2003 | 10:46 AM
b18bturbo's Avatar
Default Re: Is spark racing REALLY warrantying their manifolds??? (FFgeoff)
from what i understand they are warrantying all the manifold that are cracking its just too many of them
Now you see why i dont carry them....
[Modified by b18bturbo, 1:47 PM 3/4/2003]
Old Mar 4, 2003 | 10:52 AM
Default Re: Is spark racing REALLY warrantying their manifolds??? (b18bturbo)
i thought you did carry them?
Old Mar 4, 2003 | 11:01 AM
b18bturbo's Avatar
stopped completly.. i used to get them direct from meng at first but not anymore stopped completly..
Old Mar 4, 2003 | 12:06 PM
Tinker219's Avatar
now they are on ebay for like $200...well the OBX(same thing)....not good...
Old Mar 4, 2003 | 12:07 PM
b18bturbo's Avatar
Default Re: Is spark racing REALLY warrantying their manifolds??? (Tinker219)
yup
they are dirt cheap.. the material is thick its just not braced right from the turbo. you should brace the turbo to the block and i am sure it wont crack
Old Mar 4, 2003 | 12:40 PM
SiRkid's Avatar
its perfect for the DIY people... cheap and if you brace it, youll be fine.
Old Mar 4, 2003 | 02:35 PM
Default Re: Is spark racing REALLY warrantying their manifolds??? (SiRkid)
well brace the turbo, dont weld braces to the manifold, or they will just crack off, too. Bracing the turbo to the block is a good idea, however.
Old Mar 4, 2003 | 03:04 PM
b18bturbo's Avatar
From what tony was telling me the manifold is designed nicely just not braced well to hold heavy turbos for some reason. He said just add brace it should be okay to the engine block
Old Mar 4, 2003 | 03:26 PM
CRVRX's Avatar
I am surprized that all manifolds don't require bracing.
Even the Honda stock manifold has a brace half way down the block and under the oil pan. Every factory turbo car I've seen has a brace for the turbo.
Old Mar 4, 2003 | 06:09 PM
internet ay's Avatar
yup
yeah but what do you do when the whole runner to the wastegate breaks off at the weld. is it necessary to brace the wastegate too. evidently this manifold wasnt made to hold anything heavy, it couldnt event support the weight of a tial 40mm.
Old Mar 4, 2003 | 06:58 PM
tony1's Avatar
Default Re: Is spark racing REALLY warrantying their manifolds??? (internet izzay)
The one that i've had all the problems with was NOT warrantied. We took care of our customer, rewelded it and got him back on the road for no charge. Spark requested pics. of the cracked manifold (at the runners AND the wastegate) and then proceeded to tell us that they won't pay us for our labor to reweld it. They want us to send it back for inspection and then they'll send us another one. So, what are we supposed to do about our customer not having a car for god knows how long while we wait for them to "inspect" it? Bottom line, we took care of our customer, and Spark racing didn't take care of theirs...
Old Mar 4, 2003 | 07:36 PM
Mase's Avatar
Default Re: Is spark racing REALLY warrantying their manifolds??? (tony1)
And thats why you're the **** Tony
Old Mar 4, 2003 | 07:43 PM
ludesleep's Avatar
Default Re: Is spark racing REALLY warrantying their manifolds??? (Mase)
what do these support braces look like? anyone have a pic of a tubo supported by the block?
Old Mar 4, 2003 | 07:44 PM
Kelvin96GSR's Avatar
25 Year Member
sounds like awesome customer service
Old Mar 4, 2003 | 08:55 PM
Full-Race Javier's Avatar
Default Re: Is spark racing REALLY warrantying their manifolds??? (Boost'R'Us)
out of curiosity, what was the mani designed to support? anyone know the difference in weight between T3/T4 and T3 60-1?
Old Mar 4, 2003 | 09:03 PM
boosted hybrid's Avatar
Default Re: Is spark racing REALLY warrantying their manifolds??? (javierb14)
The differences in weight are 7-8lbs approx.
Old Mar 4, 2003 | 10:08 PM
if you really take care thats AWESOME, props to you. I just wanted to hear from anyone else who has had a manifold fail, if you do take care of them as you say thats a wonderful thing.
two other cases (freinds of mine) Agen2integra had his crack, as well as jerseykid609, they have now both had their wastegate tubes fall completely off, as well as numerous other issues. Have these issues been resolved, and what needs to be done to figure out a solution? I was asked to see if i could come up with a solution, but i havent yet.
Old Mar 4, 2003 | 10:14 PM
VaporTrail's Avatar
New User
well it's obvious to me that the wastegate portion needs to be braced. SFP braces theirs, **** almost everyone does.
Old Mar 4, 2003 | 11:19 PM
ImportReview
Guest
Posts: n/a
To be honest, that manifold is really inexpensive, and is really nice for the money. Knowing what material it is made out of, you KNOW its going to crack before you even run it eventually, unless you brace it mean.
I don't think its sparks responsibility to warranty cracks from this type of use. Everyone knows stainless manifolds crack after time, without braces. Its so inexpensive anyway, you always get what you pay for.
A Hytech or more expensive manifold that costs like 2x that much has a warranty, as it should, they are making 4x the profit on every single one they sell and can afford to take a few back.
Did I make sense? or am i wrong.
Jeff
Old Mar 5, 2003 | 05:48 PM
tony1's Avatar
TONY THIS IS ANTHONY FROM SPARKS I PAID RON $200 for your repairs that you said cost $500 I never ment a welder that charges $250 a hour if you didnt recieve those funds you better tell Kenny to talk to Ron. Also after you do I would like to Re post you statment That I do take care of my customers.
[Modified by Boost'R'Us, 6:04 AM 3/5/2003]
We took off the manifold 2 seperate times to weld it. First for the runners and second for the wastegate. Labor to remove the manifold, reweld it, and reinstall it was $250 each time. I don't think that is too much at all. Maybe you're just too used to paying Thailand labor rates....
Old Mar 5, 2003 | 07:17 PM
1fstcorrado's Avatar
do you really want a solid brace with thin wall tubing? that stuff moves around alot when it gets hot, which makes for more cracks. wouldn't you want to mount it from the top with a hiem joint or 2. so it can twist and still be supported. I am not an expert but there is right way and a wrong way to brace things, correct.
Old Mar 7, 2003 | 01:30 PM
ffgeon's Avatar
______
Also why are you so interested in my company am I hurting your sales that bad!
trust me man, your not hurting our sales at all. back at u
Old Mar 7, 2003 | 01:32 PM
Sonny's Avatar
Default Re: Is spark racing REALLY warrantying their manifolds??? (ffgeon)
Booo..bring back Michael Meyers.
Sonny
Old Mar 7, 2003 | 02:29 PM
ffgeon's Avatar
Default Re: Is spark racing REALLY warrantying their manifolds??? (Sonny)
hahaha, you guys wont stop harassing me about that huh. i gotta spice it up sometimes and change that thing every once and a while. maybe next week ill go back to it. =P
93NTEGLS
Oct 4, 2005 06:16 PM
eg6T
Sep 9, 2004 07:59 AM
streetlvlhatch
Jan 6, 2004 07:27 PM
rextec
Nov 24, 2003 12:02 PM
S2KP
Aug 21, 2003 12:26 PM
