stock shift linkage with b18a
Old Mar 4, 2003 | 10:38 AM
spun Vtec's Avatar
Default stock shift linkage with b18a
what needs to be done to the stock crx shift linkage to make it work with a b18 shortned made longer..?? i know the teg linkage getts shortned a lil less than 3 inches but what about the crx linkage?
thanks
-larry
Old Mar 4, 2003 | 11:30 AM
joshwhe's Avatar
Default Re: stock shift linkage with b18a (4gsicivichatch)
make the rex linkage longer you have to splice in the front half of the teg tho
it would be easier just to mod the teg linkage.........
i think thats what im gonna do..... anyone with input on if they like it or not would be great
[Modified by joshwhe, 12:30 PM 3/4/2003]
[Modified by joshwhe, 12:38 PM 3/4/2003]
Old Mar 4, 2003 | 08:24 PM
spun Vtec's Avatar
Default Re: stock shift linkage with b18a (joshwhe)
i havta use the crx beause i dont have the teg linkage
ill let you know how it goes
Old Mar 4, 2003 | 08:38 PM
StorminMatt's Avatar
The problem here is that the rods are backwards on the stock ED linkage. Specifically, on the ED linkage, the actual shift rod is toward the driver's side on the ED linkage but toward the passenger side on the Integra linkage. You would have to do some pretty creative bending to get the rods on the right side. And even then, the end of the torque rod on an ED linkage won't bolt to the B-series transmission. Seriously, you would have an easier time starting with a 1984-1987 Civic/CRX linkage, as it is closer to what you want. And it is cheap to buy. But even this won't be easy to modify.
import-tooner
Jan 24, 2010 07:48 AM
CRX_GUY_123
14
Apr 5, 2004 09:13 AM
See Are X
16
Sep 1, 2003 12:10 AM
BorderM3
Mar 19, 2003 05:33 PM
hardware17
May 6, 2002 01:34 PM
