stuttering with the b16
ok, i'm done doing the swap, everything is working wonderfully, except one thing, well i guess two really, one my knock sensor was kinda fucked, and now it won't stay connected, but that doesn't really bother me. The main problem is that my baby stutters, hesitates, whatever it's called it's super annoying. Now i know the jdm b16 has two o2's and i got the hasport sub-harness (waste of money i know, now) but the thing is i'm not sure if the wiring is correct, so down to the question, Which o2 sensor is the one that plugs into c8 and which ones plugs into c16?? There are two plugs in the engine bay, one has a green plug and one has a white plug, if you could identify then like this, it would be so great!!! Thanks so much you guys.
O2 sensor #1 is:
C16 on the PR3 or PW0 ecu
GREEN connector
monitors cylinders 1 & 4
O2 sensor #2 is:
C8 on the PR3 or PW0 ecu
WHITE connector
monitors cylinders 2 & 3
GREEN connector
O2 sensor #2 is:
WHITE connector
Jdmdelsolb16a
Engine Management and Tuning
May 23, 2011 07:45 AM
