tial wastegate hitting hood
Old Mar 3, 2003 | 09:48 PM
Vtecless212's Avatar
Default tial wastegate hitting hood
i have 91 civic with drag 3 manifold and t3t4 put on tial wastegate and it's hitting the hood. i know i can run some bends down to the side or notch out the hood. i was just wondering what others have done. any ideas?
Old Mar 4, 2003 | 04:26 AM
EP3_05's Avatar
Default Re: tial wastegate hitting hood (jdmturboef)
I have seen most people either buy or make a 90 degree elbow so the wastegate sits parallel to the manifold. Drag sells these elbows as do other turbo parts suppliers.
Old Mar 4, 2003 | 05:37 AM
Doodoo's Avatar
I have a 90 degree elbow from Rev-Hard. But it had to be modified shorter and re welded to fit. I had it crack twice also because of vibration.
Old Mar 4, 2003 | 05:50 PM
Default Re: tial wastegate hitting hood (Doodoo)
i finally just drilled a hole in the skeleton and now it fits fine... but thanks
Old Mar 4, 2003 | 07:19 PM
ScottEK's Avatar
Forget those methods, just cut a hole in your hood.
Old Mar 5, 2003 | 03:53 AM
Charlie Moua's Avatar
Default Re: tial wastegate hitting hood (beta13)
any more pix of the that crx?
Old Mar 5, 2003 | 07:34 AM
ScottEK's Avatar
Default Re: tial wastegate hitting hood (Charlie Moua)
I also have 3 movies of it running, sadly the movies aren't long enough to see the trap times but I believe he was in 12's. After the races I went to go look for it to get some engine bay pics but he had already took off. I asked around and it was believed that he had a B series turbo.
http://www.dumpsterdive.org/scott/movies/MOV02276.MPG [3.8 Megs]
http://www.dumpsterdive.org/scott/movies/MOV02295.MPG [3.8 Megs]
http://www.dumpsterdive.org/scott/movies/MOV02297.MPG [1.9 Megs]
Old Mar 5, 2003 | 10:41 AM
bodymodgrl's Avatar
This happened with my fiance's civic. A stock hood would not fit so he got a CF hood and it clears it will ease. Now there is actualy a gap between the hood and wastegate.
Old Mar 5, 2003 | 12:03 PM
Speed PHreak's Avatar
I notched out the hood and shaved a a bit off the top of the Tial.
buttsneeze
Nov 15, 2004 01:00 AM
BobGnarly
Aug 9, 2004 11:13 AM
flarinpnoi
Apr 28, 2004 09:41 AM
ridnmyhonda
Mar 10, 2003 04:18 PM
BoostedGSRBubble
Mar 5, 2003 07:45 PM
