how much can a d15b bottem end take?(RPM's and HP)
Old Mar 3, 2003 | 07:28 PM
90da4dr's Avatar
Loved
Default how much can a d15b bottem end take?(RPM's and HP)
I'm trying to find out what my bottem end can take. Plan on puttin A1 pistons in it and a ported a6 head on. If the rods can hold up well I will not change them. I'm on a budget. NEED SOME ADVICE. Plan on doin all this in june. Just trying to do some research.
i have a 89 civ hatch dx
[Modified by 89civ, 11:29 PM 3/3/2003]
Old Mar 3, 2003 | 08:17 PM
redzcstandardhatch's Avatar
something different
Default Re: how much can a d15b bottem end take?(RPM's and HP) (89civ)
the rods and block should handle up to 230 or so horses fine.....go nuts on it......beat the **** out of that little thing....i'm doing the same thing this summer when i find all the parts in the junkyard
Old Mar 3, 2003 | 10:49 PM
blackZC (W)
Guest
Posts: n/a
Default Re: how much can a d15b bottem end take?(RPM's and HP) (redzcstandardhatch)
i was hoping to get away with 200hp on a D series..tubo afc hack
are the bottom end all the same..d15 d16 d16z6? if so ill just use the d15 since im gonna be boostin
Old Mar 4, 2003 | 03:53 PM
something different
Default Re: how much can a d15b bottem end take?(RPM's and HP) (blackZC)
they mount the same and everything, and you can interchange heads, but the bottom ends are different......different cranks and rods i think.....similar, but not identical.
Old Mar 4, 2003 | 03:55 PM
performula's Avatar
I rev to 7.5-8K every once in a while.
Old Mar 4, 2003 | 04:09 PM
90da4dr's Avatar
Loved
Default Re: how much can a d15b bottem end take?(RPM's and HP) (performula)
what type of setup are u runnin
accord_raffi
Aug 2, 2008 02:26 PM
esteen2
May 12, 2007 08:44 AM
mawkiemarc
Sep 28, 2005 05:43 PM
drewbie*
Jun 18, 2004 01:25 PM
ViperRedCRX
Dec 17, 2002 09:45 AM
