crx weight reduction & factory weights
Old Mar 3, 2003 | 03:40 PM
untitled's Avatar
Default crx weight reduction & factory weights
i have a 88 hf which is the light 88-91 crx from the factory. i was wondering exactly what the factory weight rating is and how much i could save from gutting the interior( 1 seat, all plastic panels, spare & jack, etc.)? how much could be saved with plexiglass windows?
FOR SALE:
88 hf manifold(uncut for turbo)
stock d-series parts( 2 whole engines to pick at)
WANTED:
88-91 Si ECU
Old Mar 3, 2003 | 04:46 PM
MrTodd's Avatar
Default Re: crx weight reduction & factory weights (88crx91integra)
According to this info I have,
"1988 Honda Civic DX HB MT 1993
1988 Honda Civic HB MT 1933
1988 Honda CRX Si MT 2017
1988 Honda CRX DX MT 1922
1988 Honda CRX HF MT 1819"
Looks like your HF is approximately 1800 lbs! That's very light. If you removed the passenger seat, jack/spare, and all the plastic you might lose 70+ lbs or so... As far as replacing glass with plexiglass, your guess is as good as mine.
[Modified by MrTodd, 6:47 PM 3/3/2003]
Old Mar 3, 2003 | 04:49 PM
incubus's Avatar
Default Re: crx weight reduction & factory weights (MrTodd)
correct me if I am wrong, but the diff between a d16 and a b16 is about 60lbs right?
Old Mar 3, 2003 | 05:54 PM
Neukin's Avatar
Default Re: crx weight reduction & factory weights (incubus)
90lbs between the d16 and b16 but close enough... fal said there plex glass is 20-50lbs lighter then stock depending on car, sorry i cant be more spacific. honda-tech rules you 88crx91integra
Old Mar 3, 2003 | 06:19 PM
untitled's Avatar
Default Re: crx weight reduction & factory weights (toyosupr)
so i should be around 1700lbs after plexiglass. thats light as f***. all you guys should check out toyosupr's sale. he needs cash. right toyosupr?
Old Mar 3, 2003 | 06:24 PM
jlicrx's Avatar
you can also remove the bumper covers and take out the steel bumpers (they are only good for a 2.5mph crash anyway) and reinstall the covers - take crash bars out of doors
we have 89 STD hatch completely gutted with carbon fiber hood, all lexan windows and DOHC ZC - it weighs 1475 lbs - crx should be a little lighter.
I should clarify - we removed gas tank, filler neck and all lines and built a custom 1.5gal tank that is located up front of the motor
[Modified by jlicrx, 8:28 PM 3/3/2003]
[Modified by jlicrx, 8:40 PM 3/3/2003]
ExospeedAMcrx's Avatar
I got my 89 HF w/ d16a6 down to 1550 with out driver. No fiberglass, Stock doors, no cutting of the body. only thing diff was HAtch was made out of lexan and aluminum. Daily driven and 2 front seats.
Old Mar 3, 2003 | 06:28 PM
MrTodd's Avatar
Default Re: crx weight reduction & factory weights (jlicrx)
The '88 HF never came with steel bumpers OR side impact beams.
Old Mar 3, 2003 | 06:30 PM
jlicrx's Avatar
funniest thing, I have one sitting in the shop right now that we are building full drag and it has them?
Old Mar 3, 2003 | 06:34 PM
untitled's Avatar
i took my rear bumper off today and there was a steel reinforcment. is there anything else i could use? or is there a way to mount the bumper to the car without it?
and where did you get an aluminum and lexan hatch?
Old Mar 3, 2003 | 06:42 PM
Neukin's Avatar
kinda need cash, i think you guys should buy some stuff from 88crx91integra. the money will be well spent trust me. 1300lbs is a good goal 88crx91integra all you have to do is remove stuff... right. lets see how high we can get a pile of parts from the hf, im all for it.
[Modified by toyosupr, 10:43 PM 3/3/2003]
Old Mar 3, 2003 | 06:48 PM
untitled's Avatar
toyosupr is a funny kid. i think he wants to rip shtuff of my rex first so we can see if it is worth it on his. no i'm down. the pile is pretty big so far. weight reduction is just as important as building power. less weight to pull the less power needed to reach those 13's,12's, etc. oh yeah buy my stuff. you can cut an HF manifold and weld a turbo flange on it and you have a damn cheap turbo manifold. SO BUY IT!!!
the money is already spent anyway, right toyosupr?
Old Mar 3, 2003 | 07:04 PM
FRESH's Avatar
Any car weight wanted or spec on hp rating and anything else go to EDMUNDS.COM best site ever
Old Mar 3, 2003 | 08:29 PM
SeaBass's Avatar
From: Clueless like Shaggy n Scooby before commercial, break
Wouldn't checking your registration be the easiet way to find the weight of your car?
My 91 DX weighs in at a "hefty" 2103lbs.
Old Mar 4, 2003 | 06:02 PM
TeamUndefinedHFCRX's Avatar
i gutted my 88hf this way:
a/c: minus 60-70 lbs. (including stuff behind dash)
rear panels: 10-15lbs.
vx rims: 6lbs lighter per rim than 13"steelies: minus 24 pounds
spare and jack removed: 15-20lbs.
front and rear bumper brackets: 20lbs.
being easy on the measurements, i lost, (at the least) 130lbs,
which makes my hf about 1680lbs.
throw in an A6 with i/h/e and hit 14's haha.
Old Mar 4, 2003 | 06:04 PM
89civicdx's Avatar
Default Re: crx weight reduction & factory weights (TeamUndefinedHFCRX)
I posted this earlier today
https://honda-tech.com/zerothread?id=432797
Old Mar 6, 2003 | 10:15 PM
SmobbinSi's Avatar
Default Re: crx weight reduction & factory weights (89civicdx)
Thats funny, I just weighed my 89 CRX Si (with A/C) this past weekend, and it weighed 2,160 pounds. The gas was nearly empty and the only thing I took out of the car was the spare!
Old Mar 9, 2003 | 08:02 PM
smokey2.0's Avatar
Default Re: crx weight reduction & factory weights (exospeedAMcrx)
can you post some pictures of that car, exterior and interior? specially the hatch!
Old Mar 9, 2003 | 08:11 PM
camboMONK's Avatar
exospeedAMcrx...How did you make your hatch out of lexan/aluminum? If not then where did you get if from? Im interested.
Old Mar 9, 2003 | 08:37 PM
Default Re: crx weight reduction & factory weights (camboMONK)
Made it myself. used Aluminum for the frame and the rest was lexan. weighed less than 5lbs. of course it was permanent.
Old Mar 9, 2003 | 08:43 PM
shorti's Avatar
i heard that the exaust heat shield wieghs around 20-30lbs
lf it's not gonna be a street car make the exaust exit out of the side of the car in front of the door......then take out the shield
just a thought
[Modified by shorti, 10:44 PM 3/9/2003]
88_hatch_ls
Jul 9, 2005 03:02 PM
240sx crazy
19
Jun 5, 2005 05:28 PM
kevinoneill
Mar 1, 2005 07:45 AM
kevinoneill
30
Feb 14, 2005 08:31 AM
99teggsr
Jan 25, 2005 12:48 AM
