Need help with clutch and throttle cables...
Old Mar 3, 2003 | 12:21 PM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Need help with clutch and throttle cables...
IM in the process of installing a 92 LS into a 90 CRX. What throttle and clutch cables should i use? Ive got the stock throttle cable and a LS clutch cable. Can someone post a pic of their bay so that i could see how the throttle cable is routed? Thanks.
Sean
Old Mar 3, 2003 | 01:13 PM
Urban Business
Guest
Posts: n/a
Default Re: Need help with clutch and throttle cables... (sCeRaXn)
si throttle cable to long or what? superhatch used the ls throttle cable and it fits perfectly. stock clutch cable should as well.
Old Mar 3, 2003 | 01:37 PM
Civicdrgrcr's Avatar
From: WTF DC Racer No Way Turbo Washington., DC, USA
Default Re: Need help with clutch and throttle cables... (limoZeen)
Just go to the dealership and pay the xtra $$ get yourself a new Throttle Cable, Clutch cable is fine. I have heard that some people use the stock Throttle cable as well but no to sure.
Old Mar 3, 2003 | 05:27 PM
sCeRaXn's Avatar
Default Re: Need help with clutch and throttle cables... (Civicdrgrcr)
So my stock clutch cable will work fine...but i need a new throttle cable? has anyone ever used the stock cable? By the way...its a dx not an si...guess i should have told you that to begin with. Arent the dx throttle cables like long as hell anyway? Also i need some pics of an LS engine bay so that i can see if im missing something...which i think i am. I think that im missing the little thing that guides the trottle cable over the throttle body...i cant really explain it but if i could see a pic i would be able to tell you what it is. Thanks.
Sean
Old Mar 3, 2003 | 05:30 PM
CLICC916's Avatar
i used my stock si throttle cable and had to make a custom bracket to hold it in there...i'll get pics soon if you need em
Old Mar 3, 2003 | 05:32 PM
sCeRaXn's Avatar
Default Re: Need help with clutch and throttle cables... (CLICC916)
Sweet man...yea some pictures would help alot. Thanks
sean
Old Mar 3, 2003 | 05:46 PM
NCchris's Avatar
Hi Sean, You can use your stock clutch cable. Where the cable goes into the adjuster at the tranny, cut the plastic sheath and you can pull out the steel sheath (outer cable) shorten it about 1-1/2 inch and it will work. I just did this last week on my B18 swap. Be carefull and don't cut the inner cable. I used my dremel tool with a cutoff disc. I am also going to re-use my HF throttle cable, need a new bracket. I also went to the yard and bought a 91 Ted throttle cable and it wasn't bolt on either. Email if you have questions, I'm doing a B18 swap right now.
HTH
chris
madgeo
Jul 22, 2009 03:41 PM
CRexcellence
Dec 11, 2002 03:12 AM
S13 slide
Apr 11, 2002 08:42 AM
BoostinDC2
Feb 17, 2002 05:41 PM
