2 questions on this guys integra
one: he has a jdm rear hatch anybody know where he got it? It apparently has the wiper removed stock for jdm.
two: in his engine bay in the lower right corner he has taken out the power steering. what does that do anything?
http://www.superstreetonline.com/fea...98/index3.html
[Modified by SpoonboyChoi, 12:11 PM 3/3/2003]
2: If its removed he simply doesn't have power steering. That's it. Harder to turn the steering wheel and reduces someone engine stress as there is no power steering belt being run.
some (like myself) feel that steering is more accurate manually rather than with power steering. but turning rations for manual and power steering racks are different... so if one was to remove power steering they should do it the right way (i.e. dont just remove the belt) - they should replace the power steering rack with a manual steering rack.
1) you could probably pick up the rear hatch from nearly anybody who deals with the used jdm conv. Give IC Roger an IM and ask him.. he may be able to help you out.
2) YOuve gotten enough answers... they are correct
eric go to teamintegra.net theres instructions for the wiper removal the other diff between the jdm itr hatch is that the glass is lighter not worth it to spend on a jdm hatch just for the no wiper
