car wont start cuz its so cold??
So it just cranks over and never starts? Check to see if you have fuel and/or spark. When you first turn the key do you hear the fuel pump buzz? Hold a spark plug out of the engine while someone cranks it over and see if there is a spark. (use insulated pliers or something.) It's more than likely spark related... Could be that main relay problem but I'm not sure of the symptoms other than just not starting.
[Modified by Stew Pidasso, 3:14 PM 3/3/2003]
