F/S: Pioneer AVX-P7300DVD, AVM-P8000R & CDX-P1270
Hey guys, selling off my full dvd setup... Includes the Pioneer AVX-P7300DVD unit, AVM-P8000R brain and CDX-P1270 12-disc cd changer. The dvd player and brain are reconditioned units and are in mint condition and have only been installed for about a month. The cd changer was brand new a month ago. There are no receipts due to the fact that they were purchased online however all parts, wires, boxes, remotes and manuals are included. I do have the customs brokerage letter that states I paid tax on the total of $721.55 (had it sent undervalued and as a present) which is better than nothing. All 3 units are in mint condition and the reason Im selling them is cause Im installing the Kenwood touch screen dvd player. Heres the specs:
DVD Player Features
Ultra-Slim Built-in DVD/Video CD/CD Player
IP-Bus Input/Output
96kHz/24-bit D/A Converter
Controlled by IP-BUS Headunit Full Control by AV Entertainment Master Unit and External Control by Any IP-BUS Headunit
DVD Composite Video Output for Rear
Optical Digital Output for AV Entertainment Master Unit (DTS/Dolby Digital/Dolby Pro Logic /Linear PCM)
Remote Control
LCD Display Features
7" Wide TFT Active Matrix LCD Color Screen with 5 Selectable Viewing Modes
Fully Motorized Unit with Display Angle Adjustment
RGB Input
AV-Bus Input
Auto Dimmer Control
AGLR (Anti-Glare, Low-Reflection) Coated LCD Color Screen
Remote Control Sensor
Detachable Face Security with Theft-Deterrent Flashing LED
Pioneer AVM-P8000R
Pioneer Virtual Theater Graphical User Interface (GUI)
Easy to Control & Confirm in Full-Color Virtual-Reality World Graphics
Spectrum Analyzer & Level Indicator
Two-Way Crossover (HPF & LPF)
Front/Rear HPF (50/80/125Hz, -12dB/Oct.)
Sub-Out LPF (50/80/125Hz, -18dB/Oct.)
Sub-Out Level (-12dB to +12dB) and Phase Control
EEQ Performance Chip
3-Band Parametric Equalizer
Easy EQ (EEQ) Switches 5 Factory, 1 User EQ Presets (Super Bass, Powerful, Natural, Vocal, Flat, Custom)
Source Custom EQ Memory (Independent Custom Memory for Each Source)
Selectable Loudness Control (Low/Mid/High/Off)
Selectable FIE (Front Image Enhancer) (Rear LPF 100/160/250Hz)
MOSFET45 (45Wx4-Channel High Power)
Supertuner III
24-Station/6-Button (18FM/6AM) Presets
IP-Bus System Control:
6 & 12 Multi-CD Players
Component Single-CD or MD Players
DVD Player
TV Tuner (GEX-P7000TV)
Voice Commander (CD-VC50 & CD-VC60)
AV Inputs & Outputs
RGB Output for Front Display or Optional TV Tuner
Video Source Output (RCA-type, NTSC Video & Audio) for Rear Display
Video Source Input (RCA-type, NTSC Video & L+R Audio) for Add-on Game Consoles, VCR's and Others
Video Input for DVD (NTSC Video)
3 Pair RCA Preouts (Front + Rear + Subwoofer)
Audio/Video Independent Selector for Front Display
Independent Video Selector (Video A/B) for Rear Display
New Wireless Slim Remote Control
Pioneer CDX-P1270
12-Disc Capacity
8x Oversampling, 1-Bit D/A Converter
AGC (Automatic Gain Control) for Optimum CD Tracking Performance
Playback Compatible with Digital Audio CD-R (When disc is finalized)
Ultra-Compact Size for Increased In-Car Installation Flexibility
Vertical/Horizontal/Angled Mounting Capabilities with Multiple Mounting Angles
"Double-Floating" Anti-Vibration System
High Speed Disc Load and Access
CD-Text Decoder (for use with CD-Text encoded CD's & Compatible IP-Bus Controller)
Disc Title Memory (20 Characters per Disc, 100 Disc Max.)
ITS Memory (For programming up to 99 Tracks per Disc x 100 Discs)
24 Hour Memory Back-Up
3-Mode Repeat (Magazine/Disc/Track)
IP-Bus Compatible for use with All IP-Bus Multi-CD Player Controllers
Voice Control Available with CD-VC60 Voice Commander (Optional)
Uses the JD-1212S Magazine (One Included)
Price for the whole system in stores will run you over $3000 easy.
Buy everything for $1900. Unit can be seen in action before purchasing. If you have any questions, post here or shoot me a PM. I can also hook you up with cheap installs if needed.
Everything $1900/1250usd
AVX-P7300DVD $1300/850usd
AVM-P8000R $500/350usd *reserved*
CDX-P1270 $200/150usd
All prices are FIRM! and not taking any trades so dont bother making offers...
[Modified by DC Sports, 11:58 AM 3/3/2003]
DVD Player Features
IP-Bus Input/Output
Remote Control
RGB Input
AV-Bus Input
Auto Dimmer Control
Pioneer AVM-P8000R
Supertuner III
DVD Player
AV Inputs & Outputs
Pioneer CDX-P1270
12-Disc Capacity
