Need OBD2 P72 96+ GSR ECU pinout wiring diagram!!!
Where can I find a OBD2 P72 ECU wiring diagram which is from a 96+ GSR? I can only find information on the OBD1 P72 ECU for the 94-95 GSR online and its driving me crazy cause the harnesses are different.. thanks for your help..
im having the same problem.. im trying to wire in a field sfc and im not getting power... i think i may have a bad ground.. i grounded it to the chassis but im not getting anything.. i think i have to ground it to the power ground on the ecu. do either of you know???
heres a diagram of some pinouts.. the the one you need is on top.. the speed sensor is pin c18:
http://www.pgmfi.org/twiki/bin...rness
wow that post was from a long time ago.. can anyone help?
u2civic1
Jul 19, 2003 10:01 AM
hybridb18
Feb 6, 2003 09:54 AM
