Skunk 2 initial setup?
Old Mar 3, 2003 | 06:29 AM
White Lightnin's Avatar
Default Skunk 2 initial setup?
Installing a skunk 2 camber kit sometime this week. Should I just leave the settings as it came in the package or tey to fiddle with them before I head to the alignment shop?
Old Mar 3, 2003 | 06:33 AM
eg6ajk's Avatar
Default Re: Skunk 2 initial setup? (White Lightnin)
it all depends on what you want. if you have mad 'JDM' drift camber in the front get as much positive as you can. otherwise measure and compare
Old Mar 3, 2003 | 06:37 AM
hanson said's Avatar
Default Re: Skunk 2 initial setup? (eg6ajk)
skunk2's don't have markings on them do they? if so then you are set. if not, i'd say just take it to an alignment shop and tell em what you want...don't forget to 0 out your toe!
Old Mar 3, 2003 | 06:45 AM
racecarpete's Avatar
Default Re: Skunk 2 initial setup? (hanson said)
you can try to get it as close as possible but they are still gonna fiddle with it at the alignment shop. Just get a level and get it pretty darn close to straight and you will be set. later
Old Mar 3, 2003 | 06:53 AM
Default Re: Skunk 2 initial setup? (SilverCivic2k)
Its just that I have to drive a ways to my alignment shop of choice so I wanted to have it driveable. Thanks guys.
thatnikkashoD
Mar 10, 2008 11:39 AM
mark2583
Jul 31, 2007 04:07 AM
ware
Suspension & Brakes
Mar 1, 2007 02:24 PM
jdmstreethatch
Suspension & Brakes
Feb 4, 2006 11:52 AM
strsi
Suspension & Brakes
11
Aug 21, 2005 04:11 PM
