OBD0 => OBD2
what all do you have to change to make this work?
reason Im asking is a friend of mine has a B18A1 for cheep and Im going to replace everything in the head anyways so I was going to see what it would take to convert it to work in my hatchy
the block/head/intake can be used without a problem if its in good condition and your not bound by any state laws.
Electronics
you will require a OBDII injectors, distributor, OBDI/II thermostat housing with the temp sensor, some rewiring will be required (to the IAC)
Tranny/other
94+ Integra Hydro tranny from LS/GS/GSR or 92-00 hydro B-series tranny, clutch disc (at least to, as the flywheel and pressure plate will work off 90-1), all the mounts.
AXLES/Shift Linkage
90-3 axles can be used along with the half shaft (90-3), as well as the shift linkage.
ECU
for the ecu needs use OBDI PR4 or P75 ECU, to do that a harness converter is required
as you can see unless you're getting all this for free its cheaper to buy a complete LS swap
Electronics
Tranny/other
AXLES/Shift Linkage
ECU
TheCrimsonGhost666
Mid-Atlantic (Sales)
Feb 23, 2011 05:35 AM
SpecVtec
May 17, 2004 02:26 PM
